Question about Toshiba Satellite A100-S8111TD Notebook
Laptop to tv
I am trying to connect my gateway laptop to my older sharp tv. I do not have an s video so i purchased an HDMI cable, that didnt do it so i purchased an hd dvd player? What all do i need and is it even possible? Thanks
    Champion:
  • 258 Answers
Is your Graphic-card is compatible?
Posted on Jul 28, 2008
I want to connect my laptop to my sharp smart tv
hi look at your laptop for hdmi port if it has one connect hdmi lead if it hasn't connect vga cable from laptop to tv thanks
shaun
Mar 18, 2017 | Sharp Televison & Video
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
How to connect tv to laptop
you would need a HDMI cable I purchased a 25 foot cable at amazon.com for $20 they are about 85 at walmart for a 15 foot cable of course you nee a hdmi output on your laptop and a hdmi input on your tv they should have them if they are fairly new. hook up cable, select correct source on tv, mine is hdmi 4 .go to your laptop right click on background select properties from menuset up tv like it is a second monitor for your laptop. enjoy
Jan 12, 2012 | Sharp Computers & Internet
I have a Bose home theater system and a Sharp Aquos tv. I'm trying to hook up the Bose dvd directly to the tv. Problem - tv only has HDMI input capability and Bose does not. I purchased a HDMI convert
Hello
You haven't given any description about the converter you bought. Please send me the model number and brand name of the converter did you bought. OK.
Nov 18, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
I have connected a Roku Digital Media Player to Sharp AQUOS TV, I am able to get the video but no audio from TV, Audio cable and all are setup properly. Can anyone suggest me? also i see the same problem...
Use the HDMI cable on the Roku. The reason you don't have audio from the laptop is because the HDMI out on the laptop has no audio on it. You need to use a 3.5 mm audio cable to connect the laptop audio to the TV.
May 26, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Gateway laptop to phillips tv
Hi, there, pleasy clarify the following:
What is your Gateway model? Is your TV an older tube type or a new HDTV? Does it have other input ports besides the standard cable input and the RCA you mentioned? You may be able to use S-Video if your laptop has the output port and so does your old TV. Or if you have a newer laptop that includes DVI and you have an HDTV, then you can use a DVI to HDMI cable which by the way will result in the best image quality.
Jun 24, 2009 | Televison & Video
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
May 05, 2009 | Sharp 19 in. LCD HDTV
Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Sep 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba Satellite A100-S8111TD Notebook Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
