Question about Speed Queen AWS52NW Top Load Washer
Water leak under the rotating drum
I have speed queen front load washing machine. Water is leaking under the drum when it is agitating.
    Novelist:
  • 172 Answers
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
Why does my Kenmore washing machine leaks in front when agitating?
Most likely the sight of water leaking from the front of the machine, means it is leaking from somewhere else. Check all inlet and outlet hose connections. Hard water deposits build up and can cause minor leaks over time. If it is only noticeable during the wash cyclee,(agitating) it is possible there is a leak in the drum. Rare, but possible.
Jun 11, 2014 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer fills with water, when motor engages to agitate clicks hard and does nothing and i can smell the motor heating up.
You will need to tear down the washer and pump, the drum out to check for obstructions and other problems that are keeping the drum from rotating.
Jun 05, 2012 | Speed Queen AWS45NW Top Load Washer
Oil/grease leaking into tub. Speed Queen AWM492W top load washer. How to fix?? Thank you.
Check to see if the oil is coming from under the agitator. If it is replace the transmission. If it is not check to see if there is a grease spot inside the was tub.
Dec 29, 2010 | Speed Queen AWS75NW Top Load Washer
Model CTS90AWN Speed Queen from Alliance Laundry Systems. The unit shakes / vibrates quite a bit - I have read that this is a common problem. Also leaks a small amount of water from beneath unit (have not...
These machine like to be loaded to capacity. Under loading them is the major cause of shaking. Try loading the drum all the way lightly filled but not packed. Another thing to look for is that it was installed properly. It is very important with theses machine that they be leveled properly at install. If this was not done shaking can occur.
Dec 27, 2010 | Speed Queen CTS90AWN Front Load Washer
Speed queen Marathon top loading washer- Water leaks into drum when not in use??? Shut off valves in the basement.
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
Mar 28, 2010 | Speed Queen AWS52NW Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
My speed queen top loader is leaking water during the washing period. Water is coming out of the bottom of the washing machine while it is washing
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Nov 08, 2009 | Speed Queen AWS52NW Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Water leaking under washing machine
Had service technician come out to inspect. Problem determined to be the bearing and seal/belt. Estimated cost $350.00. It cost $450 when new....Went out and purchased a Speed Queen. Hope to have better luck.
Dec 29, 2008 | Maytag SAV2655A Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
728 people viewed this question
Top Speed Queen Washing Machines Experts
Dan Webster
Dan Webster
Chris Hall
Chris Hall
Paul Bade
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
