Question about Frigidaire GLTF1670A Front Load Washer
Spin cycle our front end loader will go through all cycles except for spin
  • Engineerguy Aug 05, 2008
    Same problem... the drum does not spin. Just rotates back and forth at low speed.. then comes to the end of the cycle and stops.
  • eogme Aug 19, 2008
    Our washer goes through the wash cycle, then at the end it just turns changing direction but never enters the spin cycle, if we manually move it to the spin cycle after a couple of tries it will spin.
  • 876 Answers
I had to have a repairman out for this problem, but before I realized that the clothes were still too wet for the dryer, my dryer actually got too hot and burned a blouse...We all have a lot to learn about these newer machines. I suggest a repairman. I wish I could help you more.
Posted on Aug 06, 2008
My front loader works fine and will spin BUT it will not do the fast final spin cycle in the end to draw water out of the clothes. It shows that it has 11 min. left, does a slow spin right, a slow sp
Hey friend, thanks for your post!
I see that your Frigidaire washer will not spin on the final cycle. You could be having an issue with your motor or control panel. It is possible that the control panel is not sending the required information to your motor in order to process the spin cycle. Or it could be that the motor is not receiving the signal from your control panel to spin.
I would recommend performing a reset on your appliance which you can do by unplugging the power cord or flipping the circuit breaker for ten minutes. I hope this information is helpful. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
My washing machine door is not opening at the end of a cycle. I put it onto another and it still won't at the end of that one. I've turned it off as well for 10 mins or so, and still nothing. Please help!
you didn't state whether it's a top or front loader. either way, there's a switch activated when the door is closed and washer is in cycle mode- so you can't open the door when a. the front loader has water in it, or b. the top loader is in agitate, or spin cycle. if top loader- there's a tab on the end opposite the hinge side that activates a switch that latches the cover closed when in 'dangerous' cycles (don't want to get your hand caught in the spin cycle!!). either a loose wire or a failed switch! prob. need to gently pop the top (should hinge back) to access the switch. UNPLUG THE WASHER!! if a a loose wire, re-attach-if not, replace switch! easy! good luck!
Apr 17, 2010 | Washing Machines
I have just purchased an 8KG Siemens front loader
Time to call the selling dealer for warranty service.
Aug 01, 2009 | Dryers
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
