Question about Maytag M7DH45B2A Dehumidifier
I Purchased a Delonghi CF08E Dehumidifier and the "Humidity switch" doesnt appear to work. I have a hygrometer and it shows the room at 50% to 55% humidity but when selecting selecting 60% or 70% on the humidity switch, the unit continues to run.Ive even selected 50% when the hygometer shows 55% and watch it drop to 47% and the unit still runs. Instructions say that once the choice of 50%,60% or 70% is chosen, the unit should shut off automatically once the humidity drops below the chosen setting. This unit is brand new and has done it straight out of box.
SOURCE: 20% humidity reading
Hi, I just cleaned my dehumidifier and had the same problem as you. I used a spray water bottle and was not aware that the humidity sensor was being soaked. Very stupid of me!! Luckily I have two same dehumidifiers and used the other sensor to replace the one that I so stupidly ruined, and behold my machine worked again. Now I have to buy another sensor. To make sure we are talking about the same thing, my sensor is white,about 1 inch by 1/2 of an inch. It as 4 wires connected to it. To access it you remove the water tank, you will see 2 screws. Remove those, and pry the front panel loose. Be careful the top of the panel is held by two plastic hooks, they break easy. The sensor is located on the right side just above the radiator, under a produting oval lip which as foam around its rim. The wire colors are red black blue and yellow. Good luck Herman
Posted on Sep 20, 2007
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
  • 1543 Answers
SOURCE: Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Posted on Sep 01, 2008
  • 44 Answers
SOURCE: My Maytag M7DH45B2A Dehumidifier turns on and runs for 30-60 seconds, then turns its self off even though the humidity level is set below what humidity is in the air. The full light does NOT come on s
Either the humidistat is weak or the bucket is in place button is vibrating against bucket and short cycling
Posted on May 28, 2009
  • 340 Answers
SOURCE: Moisture not collected
low on freon is the compressor running?
Posted on Jun 18, 2009
Daewood DHC400 works well on continuous setting, but in auto mode does not. It is showing 18 to 20 humidity while the room humidity is 50 to 60
are you sure thats not the setting thats showing not the room Rh
most homes are 70% Rh as normal !
external Rh meters can be purchased if you suspect that one on unit is not accurate for not a lot of money now
Oct 09, 2014 | Daewoo DHC-400 Dehumidifier
I cant change humidity levels
Hi Ra Ma,
After you have set the desired humidity, the readout will display the actual room humidity. It has a built in hygrometer which will be on the display while it is running.
You change it and it shows the actual levels.
See page 5 on manual.
Mar 02, 2014 | Frigidaire 70-Pint 2-Speed Dehumidifier...
My dehumidifier does not seem to be working properly. I can't find the manual to tell me what the settings should be. Would appreciate your help. It is a DeLonghi DE400P. Thanks Shirley
What is the specific problem? Is no water being collected by the dehumidifier or do you have another issue?
Make sure that the dehumidifier is in a room in the operating temperature range (at or above 44 degrees F). Make sure that the room door and windows are closed and that the room is not larger than 2200 square feet. Make sure that the collection bucket not full and is properly seated in the dehumidifier. Check and clean the air filter on the dehumidifier. (Vacuum the filter or rinse under running water three times. Then wait until dry to replace it in the dehumidifier.) Look at the coils of the dehumidifier. If you have ice on the coils, defrost the unit (turn off, unplug and wait for it to melt). If the ice reforms quickly, you may have a leak in the coolant system. Then the unit needs repair.
Next make sure that you have good air flow around the dehumidifier and that the desired humidity set point is lower than the humidity of the room.
Retrevo has the manual available: . You will need to enter a code to download the PDF.
I hope this helps.
Aug 09, 2011 | DeLonghi Dehumidifiers
I was just given a DD50PC as a gift from a friend who did not have the accompanying instruction booklet. He told me to turn the unit on and let it work. I do not know what temp to set it at. It has to...
On a dehumidifer, you set the relative humidity, not temperature. Normally the humidity should be set within 40 to 60 percent humidity.
Click on this link for a copy of the manual for your machine.
Hope this helps you.
Jul 01, 2011 | DeLonghi DD50P Dehumidifier
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
My DeLonghi DE500P dehumifier whch I purchased last fall is no longer collecting water. Everything seems to be functioning as outlined in the instructions. The rooms humidity is about 55%. Any ideas?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
Feb 07, 2011 | DeLonghi DH40P Dehumidifier
I have a delonghi dehumidifier type cf08e but have no manual
You can get the manual on the link below.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 31, 2010 | DeLonghi DE500P Dehumidifier
DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
Aug 03, 2009 | DeLonghi Dehumidifiers
Jun 18, 2009 | DeLonghi DE400P Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
301 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
