Question about Gateway GT5408 PC Desktop
IP settings is it possible to change from having a fixed IP to a dynamic IP if so how? thanks..
  • 50 Answers
Yes it is but you'll have to get the Dynamic IP from a DHCP server or a router capable of doing DHCP. If you have one of these then all you need to do is:
Control Panel
Network Connections
Double Click on the network link your using
Properties
Under the Connection uses the Following Box Click
TCP/IP
Properties
Obtain an IP Address automatically
OK
and your done. This is for XP but Vistas pretty much the same with some slight differences
Like I said before though u'll need a DHCP source external to your PC to give you an address
Posted on Apr 29, 2009
192.168.0.13
77.248.24.119 is the dns from the internet service provider
192.168.0.13 is the router address
Jul 07, 2015 | Computers & Internet
Why can I not get WI FI on my tablet? I have tried everything I can think of
With very little information it could be a number of things. Did you connect to it with a passcode? Assure your router settings are set for upnp enabled. Also, sometimes its best to give your tablet a fixed IP address rather than a dynamic one. There are free network scanner apps for tablets that will scan your network. Find out the current IP address and imput that into your DHCP reservation in your router administration. That way your tablet IP never changes. Part of your problem is i believe you have a dynamic IP set for your tablet and UPnP disabled.
Aug 24, 2014 | Tablets & eReaders
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
Changing IP Addres. Is it possible?
If you are using a dynamic IP, You can change your IP address by just resetting the modem.
If you are using a Static IP, You cannot change it. You must contact the network provider and make a request for IP change.
You can visit www.ip-details.com and have an IP lookup to ensure that your IP has really been changed.
May 10, 2013 | Computers & Internet
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
Sep 15, 2012 | Computers & Internet
It will not find my IP adress
be sure that your access point is DHCP or dynamic if not you can change it on the control panel, local area network connection. Set the your TCP/IP properties to dynamic if it was set to static.
Hope this helps. Any vote will be highly appreciated. Thanks =)
May 30, 2011 | Sony Playstation 3 (PS3) Console
My asus wl-500gP v2 can't connect to the wan properly... I get the message "you have set the wrong dynamic or stic IP address for you WL-500gP V2." I'm confused because I have it set to dynamic which...
Your ISP address is dynamic, which means every time you log on to your ISP, your WAN IP address changes, this helps to stop hacking. Your ISP even though it is cable uses PPPoE/PPPoA, so you should set your router to this, not dymamic, setting your router to dynamic will make your router look for a different IP address every time your computer tries to log to it, your computer should have e.g 192.168.1.2, which is static, you can check this by going to command prompt and typing ipconfig, see what it brings up. hope this helps and post back if you need further help.
Apr 03, 2010 | ASUS WL-500gP V2 Router
When attempting to change the ip address on hp linejet 1000q, I get a message stating this is a dynamically set parameter and it does not allow me to change the ip address??????
Somewher in the menu you need to deselect dynamic or DHCP and select STATIC for IP type...then it will allow you to set the IP address.
Dec 28, 2009 | HP LineJet 1000Q Matrix Printer
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
Dinamic ip address
  1. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
  2. Type admin for User Name, and password is blank. (do no type any thing for password.)
  3. Click OK. This logs you into the router.
  4. Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
that would fix your problem..
in case if yoy have any problem revert back with your internet service providers name.(isp).
Feb 09, 2008 | D-Link DI 514 Wireless Router (DI-514)
Gateway GT5408 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
