Question about Electrolux Refrigerators
Electrolux Fridge/Freezer Model ENN26800. Fridge stopped working Freezer o/k
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
SOURCE: ZANUSSI ELECTROLUX -- FRIDGE (TOP HALF) NOT WORKING?
9 times out of ten, when the freezer portion works, and the refrigerator portion doesn't, it is the evaporator fan that is the problem. I am not familiar with that model, so I do not know where the fan is located. But there is a fan that blows cold air from the freezer into the fridge portion. Usually, a fan blade is just stuck, and just needs to be repositioned or the bearing the motor spins on could be frozen or rusty. I little household oil usually does the trick, or you might need a new fan motor.
Another possible cause is the ice that can build up. If there is ice blocking the air's path it will have the same result. You said you had defrosted the unit, so this is not likely in your case
Posted on Dec 31, 2008
  • 37 Answers
SOURCE: electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Posted on Jan 09, 2010
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Posted on May 12, 2010
Hi, I have an Electrolux French door fridge. the freezer keeps developing ice over the back panel and then the freezer shuts down. I have turned the whole unit off for 36 hrs to defrost and then turn it...
You have a defrost issue causing frost/ice accumulation on the back panel of the freezer and stopping air flow across the low side.
When this happens the air flow is stopped to the fresh food and its gets warmer by the day until it is finally defrosted. What is your model #???
Oct 17, 2013 | Electrolux Refrigerators
Electrolux side by side refrigerator model E126SS55GSO touch pad on ice and water dispenser will not respond to touch, error code of CE on freezer and fridge temperature, alarm keeps beeping non stop. ...
You have a communication failure, check the wiring at the freezer door hinge and if it is ok replace the control beneath the unit if it continues replace the user interface as well.
Sep 22, 2013 | Electrolux Refrigerators
Freezer is working fine but the fridge has stoped workin the model number is enb5289x
I was unable to locate your specific model number but the following rules apply. The usual cause of this is a blockage in the air flow from the freezer to the fridge side.
1. Possible stick baffle valve. This a the vent that allows air to enter at the top of the fridge from the freezer. Check it for obstruction. Alternately if the return vent is blocked the same problem will occur.
2. a defrost problem will cause the air circulation to stop. This can usually be seen by a large amount of frost build up on the back wall of the freezer. This will require a more thorough diagnosis as the circuit contains several parts which could fail.
3. Bad circulation fan. This will not force the air to circulate causing a warm fridge and a cold freezer.
Jul 28, 2008 | Electrolux Refrigerators
Fridge not working
Fridge is not working then don't worry we will be here to help you.Just dial Dialfix.in number. Refrigerator Repair Services in Hyderabad DialFix
Aug 13, 2007 | Electrolux ER7926B Bottom Freezer...
Refrigerators Logo
349 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
