Question about Maytag PYE2300AY Electric Dryer
Maytag pve2300 I'll try this again! The first expert said take off the back panel to get to the belt. There is no back panel. I wrote back again and no one else replied, and it's been more than 48 hours. I would like for someone that knows what they are talking about to write me back and explain in detail how to get to the belt that turns the drum. Thanks, Derrick
    Problem Solver:
  • 6 Answers
There should be two clips on each side in the front of the dryer on the top panel, holding the top down. Use a small flat screwdriver and slip it between the top and the front panel and gently push the clips in while lifting up on the top. It hinges upwards to the rear. now look in the dryer, where the front panel attaches to the cabinet and remove the two screws holding the front panel in place. disconnect the door switch wires and swing front panel away from the dryer ( it hinges at the bottom ).Remove the front panel. The belt goes around the drum and the motor pulley, then grap the idler tension pulley and run th excess length of the belt around it. The spring tension should keep the belt on. roll the drum to make sure all is lined up and the belt won't slip off when first powered up.Reassemble in reverse order. ALLWAYS UNPLUG MACHINE BEFORE WORKING ON IT!!! Good luck. BpB
Posted on Aug 18, 2008
When I push the start button I only get a whirring noise on any of the settings and the machine won't start.
This could be the motor turning but the belt being broken. If you are mechanical inclined, you can investigate the inside of the machine, and see if the belt is broken. Replacement is not too difficult.
Any questions and I'll be more than happy to give more instruction
Joe
Sep 06, 2011 | Maytag Dryers
Dryer heats, but won't tumble. Suggestions?
Either there is no tension on the belt or the motor is not running. If you don't hear the motor, the first thing to check is whether any air blows out the vent. If you have air moving, the motor is OK and you can check for a broken belt or a problem with the tensioner pulley mounted on the motor bracket. First, reach inside the dryer and try to turn the drum by hand. If it turns very easily, belt tension is definitely the problem. If you can't turn it at all and the dryer was previously making a lot of noise, the drum has crashed due to a bad bearing or bushing pad. A stuck drum can also ruin a belt.
On most dryers, you can remove the panel under the door to look at the motor and belt tensioner. Usually you have to take off the floor trim piece way down at the bottom, then remove the screws holding the panel. The top of the panel is commonly held in place with spring clips.
On some models you have to undo screws at the back near the top, then tilt the top up like the hood on a car (there are spring clips holding the front of the top; you may need to pry with a thin piece of hardwood or a screwdriver with tape wrapped around the shaft to protect the paint on the dryer). This gives you access to clips and screws holding the front onto the dryer. If you have a broken belt, you'll need to remove the front (door assembly) anyway to replace the belt or drum bearing. (Some models have a drum bushing on a center pin in the back of the dryer; you can get at these by removing a plate on the back).
If the tensioner pulley has a lot of slop in the bearing, fix this; otherwise the belt may wobble off it again. You'll be surprised by how much quieter the dryer gets.
If the motor is not running, check for a failed starter capacitor (located inside the control panel), a bad centrifugal switch (inside the motor), bad contacts in the timer (control panel), or an open thermal fuse in the motor.
CAUTION: unplug the dryer before doing any work inside.
Jun 06, 2011 | Dryers
My Maytag MED9600SQ0 will not start. I have tried the following:Cleaned all vents, pulled plug from wall socket for 2 hours, and placed back in to reset;activated the - + buttons to reset the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | Maytag MED9600S Electric Dryer
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag A105 Washing Machine made a weird noise just as it started the spin cycle. When I opened the top lid, there was a burning smell and I could see some smoke coming out. I shut the lid again and...
This sounds like a belt burning. Something may have got caught in the pump and the belt is slipping and burning. You will need to drain all the water out first. Then remove the front panel. Tilt the machine back a little so you can reach the pump pulley and see if it turns freely. Your model has 2 belts and they both should be replaced at the same time. Adjustment on the pump belt is critical so the drive belt doesn't slip. If something is caught in the pump, whatever it is needs to be removed, or replace the pump.
Jan 03, 2010 | Maytag Washing Machines
CHanging Belt Maytag DE410 Dryer Q#2: Opening Top
Pop the top ... usually held down with spring clips
Be careful of the finish ...
Let me know what happens ...
Post a comment here for additional information/instruction
thanks for your interst in FixYa.com
Dec 11, 2009 | Computers & Internet
MAYTAG EPIC FRONTLOAD WASHER NOT DRAINING
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
Jun 16, 2009 | Maytag EPIC MFW9600S
My Maytag Legacy SAV515DEWW does not drain and spills over..
Well, turn the water off, install the old brakes (or wait for the new), and run the unit through a cycle (without clothes) to pump all the water out.
With the new brakes installed, and the drum empty of water, turn the water back on, run the unit through a cycle to confirm all works properly. If not, make the additional needed repairs before proceeding. If it works fine, then your good to go and start washing clothes again.
Jan 24, 2009 | Maytag Legacy Series Top Load Washer
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
