Error code e04 on hoover washing machine
Drain pump running when machine is switched on no matter what program is selected then in 10 seconds error code e04 appears on the display
Called hoover and they replaced the washing machine
Posted on Jul 28, 2008
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
Need help with washin machine error eo3
CHECK THE DRAIN PUMP AT THE FRONT OF THE UNIT BUT CHECK THE PIPE AS WELL JUST IN CASE YOU HAVE A COIN STUCK INSIDE IT TURNING FLAT WHEN IT IS TRYING TO EMPTY AND CHECK THE FILTERS AS WELL JUST IN CASE
Nov 05, 2014 | Hoover Washing Machines
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
Hello.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
Thanks.
Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
What is an E04 code?
On the front of the machine is a round access port. Insert a paper clip into the tiny hole and push in, rotate this cover clockwise. Access cover should come right off, now unscrew the plug covering the drain assembly, have lots of towels nearby, or a wet dry vac ready, a lot of water will come gushing out, after you have cleaned up the water find the source of the obstruction within the pump and remove the obstruction. Assembly is the reverse of removal. E04 means that it's taking to long for the pump to pump the water out, it's usually caused by foreign matter within the pump housing, whole infant socks have been know to get lodged in these pumps. Hope this helps.
Jul 25, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Drain pump not getting current
is the inop drain pump the only obvious problem or is there more?
May 27, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
5,587 people viewed this question
Top Washing Machines Experts
