Question about Brother DCP-110C All-In-One InkJet Printer
DCP-330C All in one
Hi
I had 'unable to clean' error and have dried up felt pad. Now I have 'unable to init 46' error. Any help available to reset my machine please.
Thank you
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Posted on Nov 20, 2008
My wifes printer. Could not wait for fix. Solution. Purchased another. (Brother also) Old printer on route to waste site.
Regards
Posted on Jul 28, 2008
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
My brother dcp-330c was unable to clean 46
If you are giving the error as 46 see below the error chart fix. I hope this gets you going and thanks for using Fixya. The number is 800-284-4329 What the error is saying is shown below. I copy and pasted so let me know if it doesn't show up for you and thanks for using FixYa.
Error 46 Ink absorber pad is full...replace it contact brother customer service.
46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us".
Jan 26, 2011 | Brother Office Equipment & Supplies
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean 46 error for a brother DCP-330C printer
Error "unable to clean" on Brother MFC Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Want the reset info for g46 unable to clean .dcp-330c .and would it be better to clean the waste pad as well?cheers.
Cleaning won't help as it's a counter that sets the error. It's a sealed plastic box that needs to be replaced and then reset thru service mode.Brother only gives the reset codes to authorized service centers.
Nov 27, 2009 | Brother DCP-330C All-In-One InkJet Printer
Error message; Unable to clean 46. I have been told it needs a new absorption pad. But my question is how do I change it.
You have to take off the top covers and take out he old and install the new, after that you need to enter service mode and reset the counter so the error will go away.
Oct 29, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP 110C printer error
you cant clean the waistinktank because when the felt dries up it wont take up any ink anymore! The rejected ink will flow into machine and cause serious demages!
Anyway you have forgotten to reset the eeprom code to tell the machine thta the ink absorberbox has been CHANGED!
Search here for error 46
Feb 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
756 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
