In North America, the voltage is nominally 110v. In London, 230. You may only have blown a fuse or the AC adapter, but you could have fried the whole unit.
Click the map below to travel to the RadiationNetwork.Com 's National Radiation Map.
Would you like to review realtime coastal radiation levels for North America?
The RadiationNetwork.Com 's National Radiation Map provides radiationcount data every three minutes across North America, including the Pacificcoast. Follow this link to view real time coastal radiation levels of North America.
Would you like to review realtime radiation levels in North America?
The RadiationNetwork.Com 's National Radiation Map provides radiation count data every three minutes across North America. Follow this link to view real time radiation levels in North America.
This is valid for the Satellit 750 by Eton (current owner of Grundig) When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range. If it is used in North Ameraica, you are told not to go through procedure but do it any way. SYSTEM Code setting Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display 1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages. 2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America) The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
The datasheet at this site implies that it has been tested to 100 PSI .. http://www.gsnorthamerica.com/1510.pdf
If you go to the main gsnorthamerica website (www.gsnorthamerica.com) other spec sheets and install guides are available as you dont mention the exact valve type.
If this helps please leave feedback, if not let me know and I'll try and help some more!
