Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Ex-z60 power on ..lens extracts then retracts ...lens error diplays...
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Casio exilim ex-z60 lens error retry power
the same thing happened to me &nd i took it apart &nd nothing happened .
Jul 12, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error of casio EX Z300
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Lens will not retract
With Battery out try to pull the lens towards outside
Do that gently do Don't rip it off !!!
Probably you will hear a click sound and If you do,
than put the battery back turn on and you should be fine
Every case is different so of the lens is jammed this will help
If the lens assembly is damaged than the only way is to sell the rest of the camera for parts.
Jan 29, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
My Lens wont retract on my exilm zoom ex-z60
If it is under warranty Casio can fix it for free. other wise you end up paying the labor/parts. Can become very costly. I suggest open the case and replace the plastic housing that hosts the saw wheels. Should fix the problem
Jun 23, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens wont retract
I did the same thing to my camera (twice) and I just took it back to the place where I got it. Since it was within the 6 month return period- they let me exchange it for no charge.
They told me that when the camera hits something while the lens is out, it knocks the lens out of its groove, which is why you can't get it to retract.
Dec 16, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Faulty zoom mechanism
Your lens will need to be disassembled, and most likely replaced.  If the lens housing inside is not broken, it can possibly be repaired.  Otherwise, the lens assembly will need to be replaced.
Oct 11, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
37 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
