Computers & Internet Logo
Posted on Jul 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My coputer will not let me start up windows messenger
John Anderson
Level 2:
Sergeant:
  • Expert 310 Answers
  • Posted on Jul 27, 2008
John Anderson
Expert
Level 2:
Sergeant:
Answers
310
Questions
Helped
148160
Points
659
Hi, can you give me a error message that you recieve, i would try going to www.msn.co.uk and clicking msn messenger and reinstalling the software,
if you can get me the error message can help you more..
All the best
John
Delete live chat?
  1. Open Windows Live Messenger window (sign into Messenger if you haven’t do so).
  2. Press Alt key to reveal menu bar, then click on Tools and select Options. It’s also possible to click on Show menu icon after the “Search contacts or the web” box. Alternatively, click on the logged on contact’s name on the top of the Messenger client window, and select Options.
  3. Select General (earlier version of WLM) or Sign In (current latest version of WLM) on the left pane.
  4. Deselect and uncheck the Automatically run Windows Live Messenger when I log on to Windows check box.
  5. Click OK.
Windows Live Messenger will not start itself automatically from next system boot up. User will need to start the program manually from Start Menu.
1helpful
Unable to download yahoo messenger
go to yahoo.com and download
Why wont windows live messenger down load
lose MSN
than go to
start
control panel
add&remove programs
‘windows live essentials’(if using WLM 2009)
‘windows live messenger’(if using WLM 8.5)
click on 'remove'
and then on 'repair'
wait til the wizard finishes
sign in again
=?if it does not work uninstall from the control panel
Start
control panel
add&remove programs
'windows essentials' ( if using WLM 2009)
'windows live messenger(if you use a previous version)
remove
=?if it doesn't work
? You have to use this program created by microsoft to remove WLM 9.0 beta3/WLM 2009
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e…
once started search in the programs list for "(All Users) Windows Live Messenger [14.0.5027.0908]"
mark it with a mouse click, then click on the 'remove' button'
=?Windows live Messenger 2009
http://download.live.com/?sku=messenger
?windows live messenger 8.5
http://www.microsoft.com/downloads/detai…
?PLUS live 4.80
http://www.msgpluslive.net/download/
(don't support the sponsor)
?NOTE: if you are trying to install WLM 8.5 and having problems, using Windows Installer CleanUp Utility search and remove "(all User) Windows Live Beta (all programs) [14.0.5025.904]"
=?if it doesn't work use "zapmessenger"
A regular issue faced is the dreaded “Another version of the product is already installed”, “Your computer has a newer version of MSN Messenger than the one you are trying to install”, ““Your computer has a newer version of Windows Live Messenger than the one you are trying to install”, “The feature you are trying to use is on a network resource that is unavailable” and similar messages.
http://messengergeek.spaces.live.com/blo…
http://www.softpedia.com/progDownload/Za…
Hope I helped MSN expert Dr Reed
My msn get automatically ofline
lose MSN
than go to
start
control panel
add&remove programs
click on 'remove'
sign in again
Start
control panel
add&remove programs
remove
?PLUS live 4.80
I hope I helped MSN expert Dr Reed
I would like to have sound driver in my coputer
if it is a laptop find the model of it the go to that site and look up driver downloads for that audio driver and version of windows and download and install, this applies to desktops as well.
Coputer microphone
Go to Control panel>>...>>Sound and audio devices, and ensure that audio input line (mic) is enabled and not muted.
Check on the messenger settings that you have selected the computer mic on audio input.
External hard drive not appearing on desktop
try start computer into windows now connect drive
now restart coputer leave drive connected when back in windows it should read it
Windows Media Center comes up with Windows Messenger failure, though Messenger is installed and running. This seems to cause the program Guide to be Not Available. Norman
Click Start>Run then copy this text into the run box and click OK:
RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove
This will uninstall Windows messenger 4.7 from your machine.
This is Windows messenger and not MSN messenger, Windows messenger comes bundled with all versions of XP and is meant for LAN messenging (your personal network in your home or office, if you have one)
2answers
Windowslive messenger not responding keeps coming up error8100030d
Error: 8100030d If you are receving the error code 8100030d when signing into Messenger, do the following: 1. Determine what version of Messenger is installed on the computer, and then upgrade Messenger if it is required: 1.a. Click here to determine the most recent versions of Messenger for each operating system. If you are not running the latest version for your operating system, please install the most updated version. 2. Delete the cache files for Messenger. Follow the steps below based on which version of Messenger you are using: 2.a. For MSN Messenger: 2.a.i. If you are running Windows XP or Windows 2000 click Start, click Run, type cmd , and then click OK to open the command window. 2.a.ii. If you are running Windows 98 or Windows ME, click Start, click Run, type command , and then click OK. 2.a.iii. At the command prompt, type the following commands. After each command line, press ENTER:
cd\
cd %appdata%\microsoft
cd "msn messenger"
del /s listcache.dat 2.b. For Windows Live Messenger: 2.b.i. For Windows XP
  • Right click on the Start button and then click Explore to open Windows Explorer. On the Tools menu, click Folder Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Click to clear the Hide extensions for known file types check box . Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them
C:\Documents and Settings\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts\ Your Messenger email address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
2.b.ii. For Windows Vista
  • Click Start and then click Explore to open Windows Explorer. On the Organize menu, click Folder and Search Options. Click the View tab. In the Advanced settings list, select Show hidden files and folders under Hidden Files and Folders. Clear the Hide extensions for known file types check box. Click OK to close the Folder Options window.
  • Delete the Contacts Cache folder. To do so, right-click Start, and then click Explore to open the Windows Explorer window. In the Windows Explorer window, locate the folders below and delete all the files and folders inside them.
C:\Users\ Your Windows logon name \Contacts\ Your Messenger e-mail address
C:\Users\ Your Windows logon name \AppData\Local\Microsoft\Windows Live Contacts\ Your Messenger e-mail address Note: Windows Logon name is the logon name that you use to sign in to windows. Your Messenger email address is the address that you use to sign in to Messenger.
3. Try to sign in to Messenger again.
I cant find my cam device
Shut down your computer and than re-start again if your cam isnt working .
Go to start- control panel- look for add and remove programs and delete your web cam and than
Re-stall all the cd's that came with your cam.
Dont for get to re-boot after (re-stalling) your cam
Grand Canyon Tech
Grand Canyon Tech
