Question about Refrigerators
Whydoes mist apear when a freezer door is opened
  • 41 Answers
The cold air from the freezer is condecing when it mixes with cold air making the fog looking air dan
Posted on Jul 27, 2008
In the control panel apear two bars like this - -
You have a code error that needs to be fixed. Call either your mfr or refer to manual or google the problem , include. Model # and code .
Feb 07, 2013 | Sub-Zero 700 Refrigerator Freezer...
Water collecting in bottom of freezer
Unblock the drain hose. You may have to access it from the back of the unit and it may be frozen up so you may have to fully defrost the freezer
Apr 30, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I had purchased fridge in Nov-2010 now a days in refregeator portion water drops apear on roof of this portion and fall on stuff put in fridge and spoil fruits and other dry things please send me solution....
Excess moisture can be caused by a leaky door gasket or lack of circulation between the freezer and fridge. Make sure fan freezer is working and that the damper between the freezer and fridge is open.
Sep 04, 2011 | Haier Refrigerators
Frigidare stuck on crushed ice.
I have a few ideas for you to try. On the bottom of the ice cube holder there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. The position of this plastic piece is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced.
Jul 06, 2009 | Frigidaire FRS26R4A Side by Side...
Turn on fridge
Press the Ice Off button and the Freezer button together for thirty seconds. Set your temps at 36 for refrigerator and 0 for freezer.
if that doesn't work, press the freezer button and the energy saver button for thirty seconds and do the same thing.
Jan 20, 2009 | General Electric GFSS6KKXSS Stainless...
- fridge not working following defrost
There must be a model number on the unit somewhere. Look on the door jambs on the cabinet (not door) side of the open doors.
Most modern day freezers have automatic defrost systems built in. If your does not defrost, then we need to troubleshoot why.
Post your model number, and we can proceed, assuming you or someone you know, knows how to use a multimeter and read a schematic/wiring diagram, with my help.
Jan 15, 2009 | Candy CPCA240FFK Bottom Freezer...
Kenmore freezer
Hi Robert,
Happy to help.
You need a new door seal.
But they are not easy to put on properly
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 23, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frozen Water in Pan behind freezer drawer.
yes you will have to remove the freezer door and go through the front of the unit. the door itself is the easy part to get off, it lifts off the rails, you may have to remove a screw a few inches back fromm the freezer door on both freezer rails(phillips head screw, ). empty the freezer pullout before trying to remove. after that the the pull out upper shelf comes and thenyou can remove the horizontal rails , the ice maker drops down and then the back wall can be removed
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
