Starting problem after cleanup dust in cpu. i connected power cables & monitor cable to cpu. but it not starts.if it starts with in 2 minutes auomatically turn off.
  • cokula Jan 21, 2009
    Afther i clean up dust motherboard is power down with bios error when I work back up user files.
    Everything look fine except board near processor is unusually furl. I try to reset bios remove battery for cca 30 seconds but without any effect. Motherboard don't give any beep sound. Everything seams for chipset problem or serious bios failure.
    regards.
    Genius:
  • 1,011 Answers
Check the processor fan is working or not. check its connector. Also check if there is any beep sound.
if processor fan is ok then disconnect all the cables, data and poewer cables. plug the power connector to motherboad only and listen if there is any beep sound there.
tell me after doing this, if problem doesnt solve.
regards,
Posted on Jul 27, 2008
There is just a black screen what can we do.
1 Try connecting it to a different monitor.
2. Try using another VGA and power cable of the monitor
3. Make sure the all the cables connecting the monitor to CPU and Monitor to the power source is properly connected.
if all the above fails then its a problem with the VGA card in the CPU
Sep 02, 2017 | Black Computers & Internet
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
Monitor went into power save mode and would not come back on
If your monitor is stuck in power save mode then first of all check all the power cables connected to monitor and your CPU.
After checking the connectors start the monitor if it does not come back from power save mode then lets move towards to second step.
2 . First unplug all the power cables to avoid power shock. After unplugging the power cables open the cabinet and look for the video card on *********** board.
Take the video card out and clean it with a normal eraser.Rub it on the golden pins and clean it.
Place it again at its place.
Close the cabinet and then start your monitor and your problem will be fixed.
Thanks for using Fixya.
Nov 13, 2010 | Computers & Internet
I have a new pc but i donot know how to install it this is a new pc. I want to start up it
Please connect it through Power supply via power cables and connect CPU with Monitor via VGA cable and connect Mouse and Keyboard with CPU .And press Start button .
Oct 05, 2010 | Computers & Internet
I recently placed my computer into storage. When I took it out and set it up, the CPU seemed to be running but there was nothing on the monitor and the keyboard didn't seem to be functioning. The mouse...
unplug the power cable of the CPU
press the power button for about 5-10 secs
open the tower and reseat the memory
theres 2 white clips on each side press down the white clips until the memory pop out
check the memory if theres any dust and put it back the way it was before
push the memory back in with a small force until the 2 white clips snap in
hope this help
Sep 07, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
My HP Pavillion keyboard lights up but the screen is blank what can i do?
Press num lock key of key board if num lock led is on/off then your cpu gives display to monitor Then make sure monitor cable is connected properly to cpu vga port.
When you power up the cpu press F8 key then enter in "enable vga mode" Then go to start->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
Then check.
But if num lock led is not on/off and left constant then you need to open cpu cabinet.
Refix RAM memory.Pull cmos cell from motherboard for 10 minutes.
Clean dust from all parts.
Reattach processor and it's fan.
Make sure motherboard is not ground with cabinet.
Open motherboard from cabinet and try outside of cabinet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 24, 2009 | HP (D7580-60003) Motherboard
My aunties monitor ,when she turn it on the monitor the power saving mode appears.
make sure data cable is connected from both end......One from CPU side and other from LCD side.
Oct 14, 2009 | LG Flatron L1750S 17" LCD Monitor
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Hard disk
Sounds like loose cabling within the case. Power down the system. Unplug the power cord from the PC. Open the case. Check every data cable & power cable in the PC. (Need good connections).
SATA hard drive data cable & SATA power cables can easly come loose, unlike IDE cabling which are unlikely to come loose. Banging the PC case will cause damage sooner or later! Run windows system defrag on the drive. (Also run windows Disk Cleanup). This should help speed up programs running slowly. Like a TV, PC's get dusty & dirty within the PC case. Once every couple of months, you should open the case & blow out any build up of dust. (Check connections before closing case).
If you're SATA data cable seems snug. Try cleaning the cable contact ends with alcohol & a cotton swab. (Both ends of the cable). Allow time for the alcohol to dry before reconnecting.
Good Luck!
M
Jun 06, 2008 | Intel Motherboard
Computers & Internet Logo
362 people viewed this question
David Payne
David Payne
