Question about Kitchen Ranges
Skyscan atomic clock weather station. doe not receive signal from outdoor transmitter. For the outdoor transmitter sensor light (red) does not go on. tried to take out and replace batteries and then replaced batteries did not work. also hit re set button on clock did re set but signal still not working. rest of clock works except transmitter. mode is skyscan atomic clock wireless weather station about 3-4 years old.fc equity 81690
  • Anonymous Mar 26, 2014
    Barometer always .27 inHg high. How can I adjust to correct?
    New Friend:
  • 30 Answers
Make sure the battery contcts are clean of any corrosion.
-AAT
Posted on Feb 22, 2011
SOURCE:
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
How are the batteries replaced, in the transmitter first, then the clock?
The transmitter for your radio controlled clock is the atomic clock in your region, I wouldn't advise trying to replace the batteries in it.
I am guessing you are talking about a remote wireless sensor supplied with your clock! Put good quality batteries in this and place it next to your receiver (your clock) while it registers and then you can place it outside or wherever you want it.
Jun 04, 2014 | SkyScan 86709 Atomic Wall Clock
Manual for SkyScan atomic clock -model 86742 I need to know how to change the clock to eastern time.
Hello
The SkyScan ATOMIC Clock
With the Skyscan Atomic Clock, you have the most accurate timepiece within the continent. It can receive the time signal transmitted by the National Institute of Standards and Technology (NIST), which is regulated by 3 atomic clocks and deviates less than 1 second within 3,000 years. The NIST broadcasts the time signal (WWVB, 60kHz) continuously from Fort Collins, Colorado. This signal can be received anywhere in the continental USA that long wave (AM) radio reception is possible with a portable radio. It is expected that the signal can cover a distance of over 2,000 miles from the transmitter. Therefore, your clock will receive the signal within the broadcast range anywhere an AM signal can be received; generally the signal cannot be picked up in massive metal and concrete structures unless near a window. In addition, some environmental effects (see next page) may affect the transmitting distance.
Nov 08, 2011 | SkyScan 86742 Digital Atomic Wall Clock
AI can't figure out how to set the atomic clock
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
Set the time on my skyscan atomic clock mo 8672
The clock will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
Jan 13, 2010 | SkyScan 86742 Digital Atomic Wall Clock
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Outside temperture
Try changing the batteries in the CLOCK. I had the same problem in a 3M similar clock and it didn't read the transmitter correctly or eventually, at all, when the CLOCK batteries were getting low.
Nov 19, 2008 | SkyScan 86742 Digital Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Kitchen Ranges Logo
739 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
