Question about Radio Shack Pro-82 Scanner
Cant find reset button inside scanner
Can someone help my scanner is locked and cant unlock it i press reset button on side but cant see reset button in battery conpartment
    Problem Solver:
  • 12 Answers
There is a lock/light key at bottom left hand corner of buttons hold that down until it beeps and the buttons should be unlocked
Posted on Feb 06, 2009
It says it's locked; to click ok when unlocked, But it's not locked. How to reconcile?
The physical lock may be engaged on the scanner.
Turn the scanner upside down and look for a button that slides. There should be a locked padlock symbol to one side and an unlocked padlock to the other side. Make sure the switch is set to the unlocked padlock side.
When you are not using the scanner or if you are moving it, it is a good idea to engage the lock switch so that the mechanism inside is not jolted out of alignment if it is bumped by accident.
Mar 15, 2015 | Office Equipment & Supplies
I am having trouble locking my mirage. When I press the lock button on the remote it doesn't quite lock the doors, how can I fix this?
when the battery is removed then that corrupts the CPU program. use a scanner to reset the program
Sep 10, 2014 | Cars & Trucks
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
All channels are locked out. how do I get them unlocked
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Jan 22, 2010 | Radio Shack Pro-97 Handheld Scanner
How to unlock control lock on ge monogram side by side
shoud be amatter of pressing abutton and holding in for 3-5 secs to unlock. look closely at the control panel it should indicate which button(s)
Jan 24, 2009 | GE Refrigerators
I bought an i9 cell phone but now the side to unlock feature is not functioning, therefore I cant get inside the phone
Try doing a hard reset. You press the Home button and the Lock/Off button on top at the same time, you will see the off slider but keep pressing them until you see a gray apple. Then let GO. I hope this helps.
Jan 19, 2009 | Apple iPhone Smartphone
Pro=95 key pad does not work
Hi, Have you tried switching the key lock to OFF? This could be done by pressing FUNC (2nd button topmost) then keylock (leftmost bottom button), you will then hear KeyUnlocked confirmation of 3 beeps. A last effort is to try and reset the scanner done by powering off then on again, press on the recessed reset button inside a hole on the side of the scanner (try using a straightened paper clip). Hope this be of some idea/help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Radio Shack Pro-95 Handheld Scanner
Permant child lock
Sorry man The only way I know to unlock it is with the original remote. They are available at http://www.remotes.com You have to press the M or Mute button and the F or the Function button at the same time. If the remote you have has these buttons try them. Like I said if it doesnt work, you will need an original remote. See if anyone you know has one you can borrow or the store where you bought the TV, maybe they will let you borrow one. Good Luck
Aug 12, 2006 | Apex Digital PF2020 20" TV
Radio Shack Pro-82 Scanner Logo
233 people viewed this question
Top Radio Shack Radio Communications Experts
Iron
Iron
Robert McClure
John
John
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
