Question about Sony Audio Players & Recorders
New sony blue ray bdp300 pluged into panasonic tv - but no sound - does anyone know how to fix this ... blue ray works on old tv - also plugged in p;laystation blueray and that works
  • 2,071 Answers
I bought an TLC HD tv 28mod D2700 series, but it won't connect my Panasonic blue ray recorder, comes up invalid format
try using the universal RCA cable plug connector , sometimes invalid format appears when things are not configured correctly.
Dec 06, 2016 | Samsung Televison & Video
I have a new panasonic tv a sony blue-ray player and bose sound bar. Freeview works fine. However there is no audio when using the blue-ray which is connected via HDMI.
It is possible that you have not got the right sound settings for the blue-ray or other equipment. Check that each device, especially the blue-ray is outputting the sound via the HDMI. Look at the sound settings using the remote for each device. The best sound is often obtained by using an optical lead. So if your devices have the connections for an optical lead, buy one of them and enjoy the superior sound of the blue-ray. HD channels on Freeview also offer Dolby sound, which you can get with an optical link better.
Oct 23, 2016 | Sony Audio Players & Recorders
I can not get my surround sound to work with my sony bravia HBD-E570 blue ray, while watching dish
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
Aug 02, 2013 | Sony Bravia Kdl 46Ex700 46 in. TV
I have a Sony BDP300 Blue Ray DVD Player. It plays non-blue ray dvd's fine. It plays a Celine Dion Blue Ray DVD fine. Tried to play an Netflex Blue Ray Amiela Earhart DVD and get picture but no sound. ...
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
It is recommended to use CD -R disc to create the firmware update disc. I hope you're clear with downloading the update from support page. Once you download and save the file in the folder in the computer, you can double click the file to extract. You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder. Most of the customers will be making mistake here after... We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image. I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software. Open installed nero software from computer. You may locate it under Start Menu programs. Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option) Navigate the extracted .ISO file we saved in the computer. follow the onscreen instructions. Insert the disc when ever Nero asked to insert Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
Aug 14, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Sont bdp300. Has all firmware updates and says it cant play disc. Plays all other blu ray just wont play some of the latest releases??
Just wait for new firmware, if this is common problem then firmware will be released shortly, mean while it doesn't hurt to give sony a call, just to fined out if they know about this problem.
Nov 28, 2009 | Sharp AQUOS Blu-ray Disc Player
No picture
Look under your tv settings for the pal ntc settings if you are using the av wire, if not please tell my what yoiu are using, also mak sure that youve pluged the av wire in the yello conecter av out on dvd/vhs and @ the tv AV in
Jan 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Code to enter on remote
i have new Sony BDP-S350 Blu-ray disc player. i want to connect it to E-net and some other devices, Camcoder, Pc, Laptop. i have got all HD ready cables,
I want to use the Universal Remote from my Sony Bravia LCD 42'' TV and Blu-Ray. can anyone help me?
thanks
omar
Dec 10, 2007 | Sony BDP-S300 Blu-Ray Disc Player
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
149 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
