This is a really odd situation. In that you have removed the battery and it still chirps, as if the battery was still installed, but was getting weak. So odd, that I took a look at the Owners Manual online to see what it had to say about it.
According to the Owners Manual this is a totally battery operated unit. When I read your problem/question, I thought it might also be a hardwired unit with a battery backup, in case of a power outage. But, that's not the case. I also learned that this detector can be used with a remote control.
In any event, the only thing I can think of is that the ionization feature may store some residual power, which causes the detector to chirp even if the battery is removed. I that's the case, it should weaken over time. But, in the meantime, the chirping is annoying.
In the meantime try silencing the alarm by Pressing the Test/Silence button on the alarm cover for at least 3-5 seconds. Hopefully, that will quiet it.
Also, the detector may need cleaning, as dust, dirt and lint accumulations can block the sensors.
Juts in case you've misplaced your Owners Manual, I have included a downloadable link, that you can print for future reference. http://www.firstalertstore.com/store/images/pdf/SA302CN-Dual_Sensor_Smoke_Detector.pdf
Hope this helps you.
