Hp psc 2200 copier works but I can not print from the pc
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
You need to check the ports and try to check if any pending files are left
Please perform the steps by disconnecting the USB cable from the printer.
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Stop.
4. Right click on it again and select Start.
see for the printer icon and a checkmark on it and now try to print.
Posted on Jul 27, 2008
  • JD Kiran Sagar
    JD Kiran Sagar Jul 27, 2008
    Please do not forget to re-connect the USB cable to the tower and as well as for the printer.
Printer won't work at all. ON button is lit, but won't go off when pressed, and a test page won't print from the printer itself!
Try unplugging the power cord and the PC cord for 2 minutes then plug the AC back in before connecting the PC. If that doesn't work, unplug the AC cord again and hold the power switch on the printer in while plugging the AC cord back in.If it doesn't work, try performing a semi-reset:
Remove both the cartridges and then perform the reset.
Perform a semi-full reset on your PSC 2200 by holding the button
combination given below, while plugging in the power cord.
CAUTION: A semi-full reset will reset or clear the following
information:
* Return the user settings to the factory defaults.
* Delete language and country settings on some models.
* Fax logs.
* Fax headers.
* Fax speed dial information.
Press and hold "#" and "6" buttons while on the front panel keypad,
Now insert the cartridges back. Try printing a test page from the printer itself now. If it's OK, it means that the printer is OK. If not, there could be a hardware problem with the printer.
Feb 04, 2011 | HP PSC 2355 All-In-One InkJet Printer
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Print cancelling
Try restarting the PC & Printer.When u restart it the former pages will be printed. Also,try updating the drivers. If these dont work,connect the psc to sum other machine to see whether ur own machine OS is not the culprit
May 21, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP all-in-one 2200 series printer doesn't work w/Vista
For scanning you can go to Paint/ File/ from scanner or camera
Regards from
amir.tadros@rogers.com
Dec 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
My hp psc 2200 printer goes through the motions of printing a page but the page comes out blank.
As per your original solution, I uninstalled and reinstalled the hp software and the printer is now working. Carol Scotti
Oct 04, 2008 | Office Equipment & Supplies
HP PSC 1410 ALL-IN-ONE Printer-Scanner-Copier
My HP PSC 1410 is not printing and it seems not to have any communication with my computer.
Sep 22, 2008 | HP PSC 1410 All-In-One InkJet Printer
Won't print from compter.
dude! follow instructions given int he quick start guide. you need to install driver and software correctly. so every time you switch on your pc and printer, you can see a message in the quick launch menu "HP deskJet F2100 series is ready". now you can use your pc to print.
Jul 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1210 does not print at all
i dought dust would cause that, reboot pc and unplug printer
plug printer back in then turn computer back on, if still doesnt work try a different usb port
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
k24674
jasbo
jasbo
