Question about Denon Audio Players & Recorders
DENON PMA520 Amp. Suspect left channel not working as set bias to all left and get nothing out of left speaker. Right speaker working. Tried interchanging speaker connections and get same result from Left channel, so suspect bias not working. Advice appreciated.
  • 682 Answers
You have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Posted on Jul 27, 2008
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
One speaker channel not working
Hello
You haven't given any details about your Denon amp, such as Model number. Yet I posts this solution. Check the speaker of the defective channel, by using a multimeter. Check the wire that connects to that speaker from amp. If both are Ok, the defect is with the amp itself. Just check whethere 'balance' control of the amp is set to extreme left or right. If it seems to be at one extreme end, make adjust it to the center position.
If all are OK and still you do not get any sound from one channel, the set need repair. OK.
Jan 22, 2012 | Denon Audio Players & Recorders
Hi the left channel of the surround speakers both A&B is not working. I wondered if there is a fuse inside the amp that is easily replaced . All other channels are working. thanks Andrew
A and B are front speakers.
Individual channels are not customarily fused. Amp self-protection usually cuts in if necessary.
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Feb 10, 2011 | Denon AVR-3802 Receiver
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
My denon amplifer was playing okay then the trebel
Determine if it is both left and right channels. If it is then you are looking for something that is common to both channels as the cause. It could be something to do with the tone circuit, perhaps an IC, another suspect is the bias section. And if only in one channel then at least you have something to compare it when seeking the fault.
Oct 08, 2009 | Audio Players & Recorders
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
424 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
