Reddit · r/appliancerepair8 comments · 1 year ago
Check drain hose for debris, kinks, and partial blockages. check float sensor. Make sure it moves freely. check chopper to see if full of debris ...
I just addressed a iCO error code on my 2 week old Frigidaire Gallery DW. I reset the circuit breaker as recommended online and it worked fine for another few days and then came back. Customer service cannot tell me what the error code means. They WILL NOT replace the DW, rather want to schedule a service appointment. I have no desire to repair a new DW so I am receiving a refund from the retailer I purchased from. On to the next brand!
Is their debris in air gap or in the bottom of the DW, where the drain is screened? These steps will walk you through solving basic DW problems.
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
well first, is it draining properly? Secondly, you should always run the hot water in your sink b4 starting the dw. It only brings in a little water, and if it just pulls it from the pipes, it will be house temp. Hot water is needed to activate the detergent. Also, if you are using tablets or squares, try simple powder or liquid. Always make sure that your jet dry dispenser isn't empty.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap--A clog in this part is the usual
reason that a dishwasher doesn't drain. Remove the drain line to clear
any debris from the hose or hose connection at the household drain line
connection. Reattach the hose before starting the dishwasher again.
Pump--You can reach the pump from inside the
dishwasher. Remove the lower rack, spray arm and support. Look for an
impeller, a device that spins around and forces water through the spray
arm. This is the wash impeller and beneath it is the drain impeller
that pushes the water into the drain port. Replace it if found
defective or worn out.
Drain valve/solenoid---The drain valve may have a
solenoid with lever that sticks or frozen and prevents the dishwasher
from draining. Free up the solenoid and lubricate the lever.
Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
Motor---Check it if turning or working.Turn the rotor
manually to see if stuck and free it up. Replace if defective, it is
not serviceable.
