Question about Denon Audio Players & Recorders
Can't get the rear speakers to work,just got a denon 1708 receiver.wiring is good,i think the problem is in the programing.
  • 682 Answers
Please repeat your setup again if you are sure that cables and speakers are ok.
Posted on Jul 27, 2008
Our denon 1708 only play on stereo mode,no sound when it select on 7 channel.. crackling on dolby. what is the problem on that receiver? please help
The surround sound outputs outputs ic's in the remainder of the system have opened, or there is a short in the speaker wiring, check to make sure that is not the case, if okay! you will need a repairman to assess the situation.
Mar 31, 2012 | Denon AVR-1708 Receiver
Denon avr-1708 receiver heats up and shuts off when volume turned up passed 0.0db or +0.5db. i am running 6-8" sonance 6oh speakers and have a fan blowing across the top of the receiver. it only...
Are you trying to kill it? A device has only so many emergency shut-offs it can withstand.
How are the spaces around the top, underside and back for ventilation?
0 dB isn't normally 'normal' volume.
I wonder if the fan is a self-defeating work-around because the noise might make you want to crank it up so higher so you can hear it.
Apple TV? Is it a dynamically-compressed audio signal? That would raise the average volume.
Feb 21, 2011 | Denon AVR-1708 Receiver
Denon avr -1709 how do i get it reset to factory specs
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Mar 21, 2010 | Denon AVR-1708 Receiver
No signal coming from sub woofer out
set the front speaker to small or if still set in large,set the subwoofer setting to lfe+main.
Feb 18, 2010 | Denon AVR-1708 Receiver
How to hook up a Wii to a Denon AVR 1708
If you are video switching through the Denon, you may need to make sure the inputs (analog, composite) are the same as the outputs. For example, you might have component out to the monitor, but composite in from the Wii. I don't believe the 1708 can do the upconversion. Try hooking up a yellow RCA cable from video out to the TV.
Dec 28, 2009 | Denon AVR-1708 Receiver
How to connect xbox360 to denon avr 1708 by hdmi cable
if you have an usb cord hook that up the your xbox then the avr 1708
Dec 20, 2009 | Denon AVR-1708 Receiver
Cannot get denon receiver to go into dolby digital
pres the prologic button more that ojne time
Dec 11, 2009 | Denon AVR-1708 Receiver
I have the denon avr-1708 receiver and inifinty tss-1200 speaker set up. I know the speakers are hooked up correctly because it plays FM radio just fine, but I CANNOT get it to do any type of surround...
I'm not familiar with this particular model, but it should be a option (or button) labeled "input", or "input mode", or "signal mode". Can you see on display "ANALOG" or DIGITAL when you switch receiver to TV in?
Jul 13, 2009 | Denon AVR-1708 Receiver
No picture
the reason you can't get a signal is the denon 1708 will not pass the 1080p, switch the DVD output res. to 1080i or 720p and it will work
dennis
Feb 02, 2009 | Denon AVR-1708 Receiver
Can n ot get rear surrround speakers to work
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
