Question about Agfa ePhoto CL30 Digital Camera
Agfa MSC 100 minilab jus went dead
I checked the 220volt powersupply to the machine and all fuses are OK also fitted a other comlete powersupply unit but the complete machine remain dead.
No lights comming on anywhere. Which other board could be faulty. First time in 3 years I have electronic fault and I use the machine dayly. It is fit with a D-Carrier. Please help
Anton Bester
Fotasia Photo & Digital
South Africa
Hi there did any one know where I can get the driver for d-carrier
msc 101 please!
Posted on Aug 05, 2009
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at
Sep 08, 2012 | Fisher and Paykel Washing Machines
My Singer Quantum 9960 machine was accidentally plugged into a 220volt supply as I am currently in a country that uses 220volt. The LCD screen lights up for less than one sec and then went off. I...
this happen to me exactly - i checked and the fuse is blown, which is a good thing because it will hopefully have saved the rest of the machine from being toasted. I will find out soon once i get a new fuse.
Apr 22, 2011 | Singer Sewing Machines
No power to machine. power socket is live as i have plugged in another appliance which works. does the machine have fuses?
Sounds like you need to have the mains suppressor checked out by an engineer.
Someone had this happen to them as well.
I checked fuses - ok I drained detergent water -ok I checked filter and pump - ok Machine will not start. Next step - contact customer service, however under the Sales of Goods Act 1979 I am contacting the supplier as the machine is new.
I hope you get your machine running soon.
Update The fault was as follows: Bosh Washing Machine WAE2446 Fault reported: DEAD Material: SUPPRESSOR Description: REPLACED FAULTY MAINS SUPPRESSOR
In a nut shell. The washing machine failed (went dead) because the mains suppressor was faulty. The suppressor normally filters out unwanted interference from the washing machine mains electrical supply. The part was replaced and the washing machine came back to life.
Mar 18, 2011 | Bosch Washing Machines
35mm film, preferably ISO 200 or 400, although on bright days you can easily use ISO 100 as well. You can choose between 12 (scarce and not worth it), 24 or 36 exposures and check that the film has not passed it's expiry date as it can result in poor colours and contrast.
Users have their own brand preferences, Fuji and Kodak tend to have brighter and more vivid colours, Agfa tends to be more earthy and natural in tone, and most store own brands will tend to resemble Agfa. You won't go far wrong with any of them. If you prefer you can also use monochrome (a.k.a. black and white) film, but unless it says on the side of the box that it's "C41 compatible" then you'll need to use a processing lab which specialises in monochrome. C41 is the name of the processing system used for colour film and so C41 monochrome can be processed by a regular High St or drug-store minilab.
Jan 21, 2010 | Canon Sure Shot 150U 35mm Point and Shoot...
Packard bell Iextreme dead
sorry there is no fuse u jus killed it
Sep 22, 2009 | Computers & Internet
2000 Mazda MPV radio is "dead"
try pulling all the fuses one at a time and see if any others are blown. if so replace.
Jun 23, 2009 | 2005 Mazda MPV
I was playing a cd and it just stopped. The lights went out, no power, no nothing. Seems to be dead...
There's a line fuse for these sets inside the radio on a printed circuit board. NOTE: for your safety, disconnect the radio from its power source before you open the case and poke around inside. The best way to check the fuse is with an ohm meter, but you can probably check it visually using a strong flashlight. There should be a wire filament running the length of the fuse. If it's intact, so is the fuse. If it's broken or not visible at all, the fuse is "blown" and needs to be replaced. If the fuse checks out ok, the power transformer is likely bad -- a problem that these sets are notorious for. Bose will charge you $100 for the transformer repair (unless the set is still under warranty), and having it done is strictly a matter of personal choice. My choice would be to sell the Bose on eBay as a "tech special" and pick up one of the newer HD radios. They offer much better sound at a much lower price.
May 11, 2009 | Bose Wave Radio
Dah climate control unit went dead - no lights and no temp readout.
The battery. Get another one from a salvage yard.
Apr 27, 2009 | 1991 Buick LeSabre
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Agfa ePhoto CL30 Digital Camera Logo
391 people viewed this question
Top Agfa Cameras Experts
Are you an Agfa Camera Expert? Answer questions, earn points and help others
