Wharpdale NE-3272 CD/DAB Micro System - This is brand new and switches its self off. Hiw can I get it to continue to play all day?
  • 2,071 Answers
Need to clean and resoldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click to rate.It is the only way i get paid for my work...
hope this may help;
Posted on Jul 28, 2008
Why will my CD Players (Two of Different Makes) not play Sony CDRW Audio CDs Continuously on "Repeat Modes? When a Alanis Morisette CD Repeats OK and plays continuously and does not turn off after about 14...
Have you closed the session when you made the CD? It is necessary to do that in order to play it in anything else besides the computer that made the CD.
Jul 29, 2016 | Sony Audio Players & Recorders
CD stops at any title track but won't play
With all the problems you are having you would be further ahead replacing the compact stereo system.
Jul 23, 2012 | Audio Players & Recorders
No sound from Evoke-1 DAB radio.
I've seen a few (Pure & other brands) like this.No communications between the micro and the dab module . could be either thats at fault.. Doubt it would be an economic fix. sorry.
Nov 07, 2009 | Audio Players & Recorders
Got a wharfedale NE-3272 DAB/CD Micro system,had it about four months now for my birthday.On friday(about three days ago)it started for no reason to switch itself to stand-by after about three seconds...
I had a similar problem with my wharfedale NE-3272 DAB/CD. Argos replaced it. Now the new one switches itself off when I switch to cd. I think it's one of those that look the part but are really just poorly made tat.
Sep 15, 2009 | Audio Players & Recorders
Cd player not working
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
How do i reset a HITACHI AX-M131U DAB/FM/CD/USB/MP3 MICRO HI-FI SYSTEM i want to retune it
push the funtion button till dab bomes up on the screen then push in the info button and it will start to retune dab. for a total reset just push the select button 1 second after you hold the info button for 5 seconds
Mar 09, 2008 | Audio Players & Recorders
Faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Mar 06, 2008 | Televison & Video
61 people viewed this question
