Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the lamp located in a sony rear projection 52 inch tv?
Paul
Level 2:
Sergeant:
  • Expert 381 Answers
  • Posted on Feb 22, 2011
Paul
Expert
Level 2:
Sergeant:
Answers
381
Questions
0
Helped
146062
Points
960
The model number you posted under does not have a lamp. It's Crt projection.
but if you have a different model number and if it does require a lamp, it's usually located in the front. You have to remove the lower from bezel to access it. Sometimes it on the side(Right side facing).
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
I have a 52 inch rca rear projection and has a red tint to it when dark image or picture
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Have a 52 inch Mitsubishi TV. Just replaced the
Call Mitsubishi the chassis needs to be rebuilt on this set they have been paying for the parts but you will have to pay the labor.
2helpful
Wheres is the lamp located on the sony wega 50 inch tv
remove the two small covers left and right behind the front lower panel.remove front lower panel (its a firm fit) pull in this sequence 1 rht top, 2 left top, 3&4 lower mid. lamp behind a panel just to the left of cantre, remove two screws locating it in place .pull lamp housing out
Changing the lamp in tv
take off the speaker grill. next to the left speaker will be a door with like 2 or 3 screws holding it closed. take those out and your lamp is in there held in with 3 screws. unscrew the lamp put in the new one and just reverse.
3helpful
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Lamp flashing light on 52 inch Wega
You have a bad lamp. Order a new one (an original Sony, not the crappy aftermarket replacements) and follow the instructions in your owners manul for replacing the lamp.
1helpful
2answers
Sony 52 inch hd widescreen projection tv
If my tv goes out and the Lamp light comes on what does that mean
7helpful
2answers
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
