Question about Microsoft Office Professional 2007 Full Version for PC
Incorrect percent results excel
Hi!
when i use the % button to subtract 5% from a cell containing currency frormatting ie $100.00 - 5%, the result is $99.95 which is obviously wrong. What am i doing wrong and how do i fix this to make it display the right answer?
Am very frustrated!!!
  • 10,594 Answers
Try to use this formula in excel.
=SUM(B1/A1)*100
Posted on Jul 27, 2008
How do you subtract on Excel
EXCEL view the operation as a function fX and you enter it like this: =MINUS(H21,H22) This will show up in the cell and on the function bar above the column letters. The cell number would have a value in it. In this example H21 would have the value 10,and H22 would have the value 5. The formula would reside say in H23 and would show the result of the operation as 5.
10
5
5 (Formula in cell is as shown above)
Sep 19, 2017 | Excel Computers & Internet
How do I create an Excel formula to subtract within a column, row by row?
put in result row
=A1-A2
or = A1-A2-A3
A being the column
the numbers 1 2 3 are the rows
or go to result cell type =
then click on cell then press -
then click on cell to minus then press -
the click on next cell to minus
Dec 08, 2016 | Computers & Internet
How do you subtract on Microsoft excel
  1. Select a cell
  2. in the Fx section type =SUM(
  3. Click another cell
  4. The cell should highlight and the Fx should display (for instance =SUM(C3
  5. modify the Fx to read =SUM(C3-
  6. Click another cell
  7. Fx should read (for instance) =SUM(C3-D3
  8. Modify the Fx to read =SUM(C3-D3) by adding a closing bracket
  9. Put a number in C3
  10. Put a number in D3
  11. B3 will display the result of the subtraction
Mar 08, 2015 | Microsoft Excel 2010
How do i subtract two cells and progress down a row by a day so the next day the formula subtracts the current day and previous day?
You have to start the sequence with a slightly different formula because there is no preceding value for Monday.
25525374-qztzwsd5tae24twsq5kxbvm0-3-0.jpg The rest of the formulas are running totals so they are the same just dynamically duplicated down the column add infinitum.
25525374-qztzwsd5tae24twsq5kxbvm0-3-2.jpg Just duplicate the the formula Picking up the value form the result column and subtracting the next running subtraction value.
Mar 06, 2015 | Microsoft Excel 2010
How to delete the data but keep the formulas
Formulas don't usually contain data, but display some transformation of data held in cells that do contain the data.
ie cell C3 may have a formula that says "=C1-C2"
Which means that C3 will display the result of the operation of subtracting the content of C2 from the value held in C1"
Clear out only the cells that contain the source values (C1 & C2) and your formula (C3) will remain.
Aug 29, 2014 | Computers & Internet
How do i calculate a difference in a percent?
If the value in A1 is 100, and the value of A2 is 120, then the formula =(A2/A1)-1 will return 0.2. If the cell containing the formula is then formatted to display as percentage it will show as 20%.
Dec 13, 2013 | Microsoft Excel for PC
I NEED MS EXCEL CONVERT FORMULA FOR NUMBER TO CURRENCY
Here is a very popular bit of code from Microsoft that will convert any currency amount in a cell to English words. All code and text from below here is the work of Microsoft.
Summary
This article shows you how to create a sample, user-defined function named ConvertCurrencyToEnglish() to convert a numeric value to an English word representation. For example, the function will return the following words for the number 1234.56: One Thousand Two Hundred Thirty Four Dollars And Fifty Six Cents
The Function Wizard can also be used to enter a custom function in a worksheet. To use the Function Wizard, follow these steps:
1. Click the Function Wizard button, and select User Defined under Function Category.
2. Select ConvertCurrencyToEnglish, and enter your number or cell reference.
3. Click Finish
To Create the Sample Functions
1. Insert a module sheet into a workbook. To do this in Microsoft Excel 97 or Microsoft Excel 98, point to Macro on the Tools menu, and then click Visual Basic Editor. In the Visual Basic Editor, click Module on the Insert menu. In Microsoft Excel 5.0 or 7.0, point to Macro on the Insert menu and click Module.
2. Type the following code into the module sheet.
Function ConvertCurrencyToEnglish (ByVal MyNumber)
Dim Temp
Dim Dollars, Cents
Dim DecimalPlace, Count
ReDim Place(9) As String
Place(2) = " Thousand "
Place(3) = " Million "
Place(4) = " Billion "
Place(5) = " Trillion "
' Convert MyNumber to a string, trimming extra spaces.
MyNumber = Trim(Str(MyNumber))
' Find decimal place.
DecimalPlace = InStr(MyNumber, ".")
' If we find decimal place...
If DecimalPlace > 0 Then
' Convert cents
Temp = Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2)
Cents = ConvertTens(Temp)
' Strip off cents from remainder to convert.
MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
End If
Count = 1
Do While MyNumber <> ""
' Convert last 3 digits of MyNumber to English dollars.
Temp = ConvertHundreds(Right(MyNumber, 3))
If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
If Len(MyNumber) > 3 Then
' Remove last 3 converted digits from MyNumber.
MyNumber = Left(MyNumber, Len(MyNumber) - 3)
Else
MyNumber = ""
End If
Count = Count + 1
Loop
' Clean up dollars.
Select Case Dollars
Case ""
Dollars = "No Dollars"
Case "One"
Dollars = "One Dollar"
Case Else
Dollars = Dollars & " Dollars"
End Select
' Clean up cents.
Select Case Cents
Case ""
Cents = " And No Cents"
Case "One"
Cents = " And One Cent"
Case Else
Cents = " And " & Cents & " Cents"
End Select
ConvertCurrencyToEnglish = Dollars & Cents
End Function
Private Function ConvertHundreds (ByVal MyNumber)
Dim Result As String
' Exit if there is nothing to convert.
If Val(MyNumber) = 0 Then Exit Function
' Append leading zeros to number.
MyNumber = Right("000" & MyNumber, 3)
' Do we have a hundreds place digit to convert?
If Left(MyNumber, 1) <> "0" Then
Result = ConvertDigit(Left(MyNumber, 1)) & " Hundred "
End If
' Do we have a tens place digit to convert?
If Mid(MyNumber, 2, 1) <> "0" Then
Result = Result & ConvertTens(Mid(MyNumber, 2))
Else
' If not, then convert the ones place digit.
Result = Result & ConvertDigit(Mid(MyNumber, 3))
End If
ConvertHundreds = Trim(Result)
End Function
Private Function ConvertTens (ByVal MyTens)
' Is value between 10 and 19?
If Val(Left(MyTens, 1)) = 1 Then
Select Case Val(MyTens)
Case 10: Result = "Ten"
Case 11: Result = "Eleven"
Case 12: Result = "Twelve"
Case 13: Result = "Thirteen"
Case 14: Result = "Fourteen"
Case 15: Result = "Fifteen"
Case 16: Result = "Sixteen"
Case 17: Result = "Seventeen"
Case 18: Result = "Eighteen"
Case 19: Result = "Nineteen"
Case Else
End Select
Else
' .. otherwise it's between 20 and 99.
Select Case Val(Left(MyTens, 1))
Case 2: Result = "Twenty "
Case 3: Result = "Thirty "
Case 4: Result = "Forty "
Case 5: Result = "Fifty "
Case 6: Result = "Sixty "
Case 7: Result = "Seventy "
Case 8: Result = "Eighty "
Case 9: Result = "Ninety "
Case Else
End Select
' Convert ones place digit.
Result = Result & ConvertDigit(Right(MyTens, 1))
End If
ConvertTens = Result
End Function
Private Function ConvertDigit (ByVal MyDigit)
Select Case Val(MyDigit)
Case 1: ConvertDigit = "One"
Case 2: ConvertDigit = "Two"
Case 3: ConvertDigit = "Three"
Case 4: ConvertDigit = "Four"
Case 5: ConvertDigit = "Five"
Case 6: ConvertDigit = "Six"
Case 7: ConvertDigit = "Seven"
Case 8: ConvertDigit = "Eight"
Case 9: ConvertDigit = "Nine"
Case Else: ConvertDigit = ""
End Select
End Function
Apr 15, 2010 | Broderbund Learn MS Windows XP and Excel...
Circular reference working how to open excel file
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Nov 20, 2008 | Microsoft Excel for PC
CASIO ms-7TV
To change the task number you must press and hold % (rate set) for 3 to 5 seconds, should appear tax XX %, now type your tax number and press % again and AC. To test type "100" press TAX + and the result should be 110, if your tax rate is 10% for example.
Jul 21, 2008 | Office Equipment & Supplies
Getting the excel formula
Suppose the value for $ is stored in cell A3. Your formula would look like this: =(A3+A3*0.25)*1.5
The equals sign at the beginning of the formula is necessary. And if you want the result to be formatted as currency, you can do so by right-clicking the cell or column, format cell, number tab, choose currency.
Nov 15, 2007 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
