Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
I recently purchased a hdmi-to-dvi cable for my Hannspree 22" wide screen monitor.
When I plug it in the monitor doesn't recognize the cord and saying "check the connection"
I purchased the cord so I could have aspect ratio scaling on my monitor but to no avail :(
Can someone help me?
    Problem Solver:
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
Dvi output on sound card'
DVI connections only transfers video (it's not like HDMI). You can continue using your current soundcard to output to the LCD monitor.
Dec 27, 2007 | Computers & Internet
Have vertical lines on my Hannspree HF257 TV-MONITOR
please try the unit with a different cable or a computer check if issue persist , cos it could also be an issue with video card or cables (vga, dvi ,hdmi) -Surendar
Jun 08, 2012 | Hannspree Computers & Internet
How do you connect LG W2261 VP Monitor to HP Pavilion 6310uk Desktop
The computer has VGA, DVI-I (dual link) and HDMI ports. The monitor has VGA, DVI and HDMI but only came with a VGA cable. Some computers have recently come with shielding covering all of the ports except the one that is currently live. Thus, check your hardware; the computers I've seen with only one active port, the HDMI port was active before resetting the video options. So get an HDMI cable (it will provide the best signal in addition). If the DVI-I port is currently live, you should get that cable as well and then change the settings to enable the HDMI port.
I hope this helps.
(you do not need to get the super-expensive cables; the low end ones will be fine. However a single link DVI cable is not the same as a dual link cable; sometimes using the wrong cable leads to no signal to the monitor.)
Oct 12, 2010 | LG W2261V 22" LCD Monitor
I do not know how to find the AV program, so as
I am not sure what you mean by the "AV program". I am going to take a guess that you mean the video input channel. Well with monitors they really do not have those.
If you can let me know the exact model of monitor you have an can double check your connections and setting for you.
Now since you have a PS3 the best connection for you to be using is the DVI port on the monitor. Now since most monitors do not have an HDMI port you will neeed to get a HDMI to DVI cable.
Let me know if this is how you have it connected and are still having trouble getting the monitor to work.
Feb 04, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
PS3 to Infocus LP 350 projector using HDMI
M1-DA is a type of DVI connection that produces both analogue and digital signals, the easiest and most quality source cable for you to get is a HDMI to M1-DA cable which is now widely available for purchase.
Infocus should have included this cable in with your projector, but instead the power at bee decided to put a M1-DA to DVI-D cable instead when most visual devices now support HDMI and not DVI nowadays.
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Where do I find a manual for Hannspree wide screen monitor 27.5"
Feb 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
985 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
