Question about DeLonghi CF210 Portable Air Conditioner
Delonghi cf210 when setting temp it dosnt give any heay
When temp is set wont go up stays cold
Just bought one.It looks like the thermostat has problem. Set at 78 F, it runs forever and the room temp is 72F. Set at 79F, it runs, room temp shows 73 F, sometimes 75F or 77F. The Ac is on then off every 5 minutes even the desired temp (is set) reached. Lousy machine.
Posted on Aug 11, 2008
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
SAMSUNG REFRIGERATOR
Check to see if the condenser fan is working. Samsung has a notoriously bad condenser fan motor. This is the compartment in back. Check that forst before replacing the control board.
Mar 22, 2015 | Samsung Refrigerators
Fan comes on; however, can't get the desired temperature to set. I select it and two seconds later it shows a higher temperature.
Hi Kate, When you press the button for your desired temperatre setting it will show this temp' say 17*c for a few seconds then it will revert back to showing the actual room temp' say 23*c, it should then cool the room down to what you set it at. hope this helps.
Sep 03, 2013 | DeLonghi CF210 Portable Air Conditioner
Delonghi cf208 the dehumidifier mode does not seem to do anything, any suggestions
I have the same model. It works brilliantly as we tend to dry the washing inside this time of year. When on dry mode try turning the "set temp" down to 17'c this normally starts mine off,,, failing that put some washing in a warm room with the dehumidifier "temp set" at 17'c just to test it maybe. or perhaps its just not humid enough where you are placing it? Good luck.
Sep 15, 2012 | DeLonghi CF210 Portable Air Conditioner
We ahve a delonghi c210 and it reads E3 how can wee fix this we tried another outlet and still wont run?
E3 indicates that the air in take filter is clogged and needs to be removed and cleaned. Be sure to turn the unit OFF and unplug it, before removing the filter.
Sep 05, 2011 | DeLonghi CF210 Portable Air Conditioner
I hav lost my owners manual and my transfarmer has burnt . i want to know the exact rating input voltage for my delonghi CF210 so that i can order for a new transformer .( In my country normal house...
According to Delonghi: "The outlet's power supply corresponds to the value indicated on the rating label on the back of the appliance." If that fails you can contact Delonghi Customer Service by email
customerservice@delonghiusa.info
Hope this helps you.
Jun 29, 2011 | DeLonghi CF210 Portable Air Conditioner
Temp will not set above 32 degrees but will go
You may have a thermsotat problem if you get it to cool that low it will cause the condensor to freeze and will stop it from working.
Jun 05, 2010 | DeLonghi CF210 Portable Air Conditioner
How do u reset temp,everytime i set it to 63 it
I think you will find that when you set the temperature, you are setting it to its lowest or ideal setting for you. When it jumps back its jumping to the temperature within its own guage reading, ie the second temperature is what it is at the moment. then it endeavers to lower that temperature to the one set by yourself. if you run the machine and keep an eye on it you should find that "jumped back" reading slowly reducing. I hope that helps(its what i,ve found anyway)
Jun 21, 2009 | DeLonghi CF210 Portable Air Conditioner
Delonghi parts
hardware stores would be a cheaper way in the plumbing section
Jul 31, 2008 | DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
164 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
