Question about Samsung Lands Phones
THE INITIAL SCREEN IS IN 2 HALVES - Samsung Lands Phones
  • 85 Answers
Replace your lcd initial screen.
Posted on Jul 30, 2008
Replacement screen for meep tablet
follow this steps and fix it. God bless you
    • 1
      Turn off your tablet and turn the unit over. Use the tip of your small Phillips screwdriver to pop the rubber pads off of the screws on each corner of the rear of the unit.
    • 2
      Remove the four screws from the corners of the back of the tablet.
    • 3
      Insert the tip of your case opener tool in the seam where the front and back halves of the unit meet. Work your way around the sides, popping the internal locking clips as you go. Continue until the two halves separate.
    • 4
      Unplug the screen ribbon which runs from the back of the screen in the front half of the unit to the motherboard located in the back half of the unit. Set the back half of the unit aside and you will see the back of the LCD screen in the front half of the unit.
    • 5
      Remove the LCD screen from the housing and fit a new one in its place. Reverse the steps for reassembly.
Jul 28, 2013 | Cell Phones
For lunch, Marco is having peach halves on cottage cheese and lettuce. The lettuce has 2 calories; the 3 peach halves each have 81 calories, and each ounce of cottage cheese has 20 calories. If Marco wants...
3 Peach Halves at 81 calories = 243 calories + lettuce at 2 calories = 245 calories
385 calories total - above 245 calories = 140 calories
140 calories / 20 calories per ounce = 7 ounces of cottage cheese
Aug 01, 2011 | Computers & Internet
I have an Acer aspire one model #KAV60 and Im replacing the screen and can only find 2 screws on the front behind the rubber plugs
Yup, that's all they usually have...now it's time to get out the plastic wedge, and start separating the 2 halves on the screen cover!
Watch the lid locking clips as you separate the two halves.
After that, it's pretty much a walk in the park. Just remember to mark what screws came from where and you'll be fine. If not, send a reply here.
Feb 25, 2011 | Aspire Computers & Internet
Brocken door spring
If you have not rectified your problem, you need to seperate the 2 door halves by removing all screws securing the 2 halves, and prize`appart, then you can easily change the spring.
Please rate my solution.
Thanks.
Oct 05, 2009 | Hotpoint WMA40 Front Load Washer
I want to change my konica sitios 7020 printer to english,its in japanese
Procedure
Touch 1. System Initial on the Key Operator Mode Screen to display the System
Initial Setting Menu Screen.
2 Touch 2. Language to display the Language Selection Screen.
3 Touch ENGLISH, FRENCH, SPANISH, GERMAN, or ITALIAN
Touch OK to complete the setting and return to the System Initial Setting Menu
Screen.
5 Touch RETURN to restore the Key Operator Mode Screen.
6 If no further changes are required, touch RETURN to restore the Basic Screen to
perform copying operations
Jun 11, 2009 | Konica Minolta Office Equipment & Supplies
Need to instructions on how to replace screen
I was able to lift the covers on the screws that keep the two halves of the cover in place. Once removed gentle prying seperated the two halves. Replacing the screen was relatively easy and obvious.
Jan 18, 2009 | AT&T LG CU515 Cell Phone - Black
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Lands Phones Logo
19 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
