Question about Dell Inspiron 6400 Notebook
Screen won't work!!!
My cpu is just about a year old and the screen won't turn on! I'm pretty sure that the actual cpu is fine because the lights are normal and it sounds like it's starting up fine but when i hooked it up to the tv you still couldn't see the screen! Could you please help me?
  • Dell Master
  • 32,281 Answers
You could have a faulty video controller.
With laptops you can switch between the LCD and the external video connector, to switch between the LCD and external connector you need to press and hold down the Fn key and press one of the Function keys, (maybe F4, F6, F7 etc) to toggle between LCD and the external connector.
If you can get a video signal to the external connector, it would indicate the video card is probably OK.
then the fault could be the LCD and or the Back lighting on the LCD.
Posted on Jul 27, 2008
My Sony Vaio PCG-61611L won't power on, the battery is fully charged and AC adapter is working (green light goes on). Please help!
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 15, 2012 | Sony Computers & Internet
I believe my AC unit is 5 years old and we have recently moved into a new house. It was working fine prior to this.
Hello Joe,
I am pretty sure I can help help your problem. But I believe maybe you forgot to tell me what is or is not doing. Please can you give me some details. Write me back and i will be glad to help you. Mike
Oct 18, 2011 | Heating & Cooling
PS3 shows red picture on TV
PS3 Red Screen Of Death Fix
If you are getting the PS3 red screen then you need to fix this and you can do so with a good repair guide or send it in.
To actually see how to fix the PS3 Red Screen check out the link below:
Hope this helps?
Oct 12, 2011 | Sony Playstation 3 (PS3) Console
My cpu fan is not working in my Gigabyte GA-8ST667 system can anyone tell me why am sure the cpu fan is good
Hello elscomputers: If you are sure that there is no other issue with the motherboard -- It was working before the CPU Fan/Heatsink stopped working. Other than making sure that it is correctly connected as shown below -- attached to Pin 1 with all three pins connected (not off to the side by one pin), you can assume it's bad (they do wear out). The cost of a new cooler is pretty minimal and I would just replace it.
Good Luck and Thanks for inquiring at Fix Ya.
Mikeywaf
Mar 22, 2011 | Gigabyte GA-8ST667-L Motherboard
No POST/Black Screen
Believe it or not, clearing the CMOS might actually help. Make sure you do it right by completely unplug the power cord or turn off the PSU, then take the battery out.
It also sounds like the CPU might be too hot. Look under the fan of the heatsink and see if there is any dust that will block the airflow. When the computer is on, touch the heatsink and feel if it is really warm. If it is really warm, it's a good sign, you might just need more airflow. If it is cold, you might need to reinstall the heatsink/apply new thermal compounds.
Mar 07, 2010 | Gigabyte Computers & Internet
My 195TF is pitch black. Dead or can be fixed?
open the CPU then find the memory and video card then clean both using a paper eraser....good luck....
May 28, 2009 | KDS Avitron 195TF Monitor
Computer wont work when 2x2 connector is plugged in
sounds like a cpu problem, or a failing power supply.
Dec 28, 2008 | Intel Motherboard
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
thanks
roger
Nov 12, 2008 | AOpen AK77-8XN Motherboard
CPU Fan not running
If the system is a couple of years old, the fan may be clogged with dust so the blade can't turn; these little suckers don't have much torque.
You can find the little fan pretty easy since (unless you have a high-end video or sound card) it will be the only one actually on the system board.
If you know how to access the BIOS on your particular computer, you may have one that monitors the CPU temperature and tells you in degrees.
Watch the screen at bootup for a message about entering 'Setup.'
This will give you the key to press and it often must be done very quickly; it's often F1 or F2.
Some BIOS will call the function Advanced or System something.
Don't make any changes you don't understand and when you exit, don't 'Save' any changes.
Aug 13, 2008 | AMD (WBK38) CPU Fan
Dell Inspiron 6400 Notebook Logo
43 people viewed this question
Alun Cox
