Question about Microsoft MS Xbox 360 Common Controller (DHC8G00004)
XBox control My xbox control on gears of war, keeps on "spinning". When i press the B button, it stops, and the left stick does not work for me to walk. On any car game, I only get the side view, but if i press B i get the normal view from the back. I've tried to reconnecting the control, but nothing. I also put new batteries. Could something be stuck in the remote? I do not have the right tools to open it. Please help. Thanks
  • Jason Lacy May 11, 2010
    Is it spinning in-game, or is the actual stick on the controller "spinning?" If it is the stick spinning, than it is most likely broken.
    Problem Solver:
  • 7 Answers
It's broken. Just buy another one.
Posted on Dec 29, 2008
The lights keep blinking but nothing is happening. It wont connect to the console. What should I do?
It's possible the xbox 360 controller isn't connected to the xbox 360. Turn the xbox 360 on by pressing the power button, and wait until it reaches the dash board. Then press the controller syncing button on the xbox 360 itself and wait until the xbox 360's ring lights start to spin around. Then press and hold the synch button on the controller (located near the charge port) and the controller should synch up with the xbox 360.
Mar 28, 2011 | Microsoft Xbox 360 Controller
The second controller won't work with my xbox360 so that 2 of us can play
Your second controller is probably not synchronized with the xbox. there is a small white button on the top of the controller. Press and hold it until the lights on the xbox guide button starts to glow and spin (only works if the controller is on). Then press and hold a small white button located on your xbox located to the left of the xbox power button, it will light up and do the same. The xbox and the controller will find each other.
Note that I am talking about the old white version of the xbox. For the new xbox slim you press the small black button next to the USB ports on the front.
Hope this helps : )
Dec 30, 2010 | Video Game Consoles & Games
Cant get controllers to connect to the x-box
Under the second memory stick port is a little buttton, when you press that button the green led of the xbox should be spinning. When it is press the same button located on the top of the controller of the Xbox until it starts spinning. At that point they should both pair up.
Rylan
Dec 28, 2010 | Microsoft Xbox 360 Console
Xbox 360 is not letting my controller connect i tried unpluging my HDD I think it is broken because when i turn it on the little ring that spins does not spin What can I do?
did you sync the controller there is a button on the xbox on the front to the bottom left of the power ring press this and then there is the same button on the top of the stick that you press
Oct 16, 2010 | Microsoft Xbox 360 Console
Xbox 360 wireless controller left analog stick problem
Thats how modern warfare is made, I also had the same problem. Try keeping it pressed for longer instead of letting go early.
Mar 13, 2010 | Microsoft Xbox 360 Controller
My gow 2 keeps freezing
If your Gears of war 2 is freezing there is a couple things to try, first try to look in your saved games for a currupt file. if there is no currupt file you can also clear the cache
  1. Reattach the Xbox Hard Drive.
  2. Locate the System section of the Xbox 360 Dashboard.
  3. Select Memory, and then press the Y button to view the device options screen.
  4. On the Xbox 360 Controller, press the following items in this sequence:
    • X button
    • X button
    • Left bumper
    • Right bumper
    • X button
    • X button
  5. When you are prompted to confirm system maintenance, press the A button to select Yes.
if that does not work. check yoru disc for scratches. it could be the disc. Maybe try the disc in another console. If you are still having issue's after all of that call in to support or go to xbox.com for more trouble shooting steps
good luck
John
Mar 28, 2009 | Sony PlayStation 2 Slimline Console
Gears of War 2 Loads but says "disk unredable."
You have a problem with your Xbox. 3 Game discs arent all faulty.
Call a service agent and tell them your Xbox cannot read discs.
Jan 04, 2009 | Microsoft Gears of War for Xbox 360
Gears of war 2 won't load
this only happens with gears of war 2?? ...if so your unlucky and got yourself a faulty disc..or if you watch a copied dvd that messes it up and you'll need a new one.
Dec 25, 2008 | Microsoft Gears of War for Xbox 360
I can't figure out how to set up the 2nd controller so I can play multiplayer.
you have to turn the controler on and choose the second players acount. turn on solo mode and let player 2 press start.
Dec 03, 2008 | Microsoft Gears of War for Xbox 360
Programming Xbox 360 wireless controller
asked me nephew for this ?
press the little white button on the xbox 360,
and the green light should be spinning,
now on the controller,
press and hold the little white button on the top till one green curve fills in the X on the controller.
should now be ready to use.
hope this works for you.
riz.
Feb 04, 2008 | Microsoft Xbox 360 Console
Microsoft MS Xbox 360 Common Controller (DHC8G00004) Logo
116 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
