Question about HP Compaq Business NX9110 Notebook
Hp nx9110 laptop
i have been given a nx9110 laptop,only thing is when i try to start it,it comes up with the message unable to find hard drive.
i know the hard drive is their,and is connected.
is their anything somebody could suggest doing,before i purchase a new hard drive.
  • HP Master
  • 32,281 Answers
There are several ways you can check if you have a working hard drive in your laptop.
1. Get into the BIOS configuration of your laptop, you may be able to see your laptop's configuration, and maybe even see your hard disk. This means your computer has been configured to work with the hard disk, but does not mean the hard disk is OK
2. If your laptop has a floppy disk attached then you can use a boot floppy disk and boot up in DOS. Then you can then run FDISK and then display the hard disk. If FDISK does not detect a hard disk the it is most likely dead.
3. If you can get access to a USB hard drive adapter cable or an IDE adapter cable that you can connect to a working computer's secondary IDE controller. THEN
Remove your laptop drive and connect and connect it to the USB adaptor or an IDE cable, (make sure you connect the drive correctly to the connector) then connect it to a working computer.
If you use an USB adapter, when you connect it to a working compute with XP or Vista operating system, and if the hard drive is OK then you will see the contents of the laptop hard drive.
If you connect the IDE cable to the secondary contriller and then boot up the working computer with XP or Vista operating system, if the laptop drive is OK you should see the contents of the laptop hard drive.
If you don't see the hard drive, then most likelt it is dead.
Posted on Jul 27, 2008
When i try to install win xp or microsoft office error message about missing files and lost drivers ??? compac nx9110
If you try to install from cd/dvd drive, your optical drive lens can't read data well and resulting to delay transfer of data or error installation.Try cleaning the lens with cotton or lens cleaner and try again. Or maybe you have bad installer.
Apr 04, 2010 | HP Compaq Business NX9110 Notebook
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Cannot read cd's written on nx9110 on any other machine
Hi there , sound like it is a software problem , if you can only read it on that compaq , it may be the permision setting in the writing software , if you cannot change these setting you could try installing a different writing programme .
Dec 20, 2008 | HP Compaq Business NX9110 Notebook
HP Compaq nx 9110 windows xp will not start up
Hi there , have had the same type of display problems with the same model , goes into sleep mode or something similar in the end i downloaded a bois update from hp & installed it , seems
to have helped the problem settle down .
Nov 22, 2008 | HP Compaq Business NX9110 Notebook
HP compaq nx9110 BIOS battery/hd not detected
Hi there , if the main battery is removed the cmos battery will go flat , if its a small pcb mounted 1 you can short the contacts for a short time , if the cdrom is working it mains the 5volt supply is ok and you should be able to hear the hard drive spin up unless there is damage to the pins on the hdd or the adaptor or hdd is mounted wrong .
Aug 10, 2008 | HP Compaq Business NX9110 Notebook
Hard Drive
u have to boot xp on it with your cds set bios to cd 1st then put xp cd in it ask hit any key to boot in ten formattt new hard drive make partions ect then install xp ok
Jan 23, 2008 | HP nx9110 Notebook
HP nx9110 low battery alarms
have you gone to control panel page? energy management systems? if there you cannot change maybe you also can change it on bios because some laptops also have this options in bios
Aug 27, 2007 | HP nx9110 Notebook
Laptop Freez up only a few minutes after I turn it on.
You possibly have to many programs starting up when you turn on computer,try going into msconfig and turning off things that you don't need to start up.
Apr 26, 2007 | HP Compaq Business NX9110 Notebook
Predicted hard drive failure
Sounds as if it's the end for your hardrive, although check it'd connection to the motherboard is ok. If you check you hard drive manufacturer, it may have a 3-5 year warranty period.
Oct 31, 2006 | HP NX9008 PC Notebook
HP Compaq Business NX9110 Notebook Logo
180 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
