Question about Linksys Wireless-G WRT54G Router
Wi Fi on Laptop
I need the shortcut/combination key for turn on wi-fi on laptop
  • rahul zip Jul 28, 2008
    Thanks kakee.
    it worked
    thanks
How to kerat the key
Posted on Jul 28, 2008
    Genius:
  • 1,269 Answers
What's the brand of your laptop? Usually the key combination is Fn F2
Posted on Jul 27, 2008
  • Michael Galve
    Michael Galve Jul 28, 2008
    You mean how to create a wireless security key on the router? Or how to get the key?
    To enable wireless security on the router.
    1. Connect your laptop hardwired to the router first on port 1. Open Internet Explorer, on the Address Bar type http://192.168.1.1 and press Enter.
    2. It will prompt you for username and password. Leave it blank on username and type admin for the password and hit OK.
    3. Click on Wireless tab at the top. Then below that, there's a sub-tab called Wireless Security, click that.
    4. Look for Security Mode and choose WPA-Personal. Type a password on the WPA Shared Key box. The password needs to be at least 8 characters. Then Click on Save Settings at the bottom.
    5. On your laptop, connect to a wireless network. It will ask you for a network key and that's the password that you've just careated on the WPA Shared key.
  • Michael Galve
    If you just wanna know your network key, do the ff steps:
    4. If the Security Mode is set to WPA-Personal, your network key is the code on the WPA Shared Key box. If the Security Mode is set to WEP, your network key is the code on the WEP Key 1 box.
    Hope that helps.
Can't get wi-fi connection
There are a number of reasons why you may not get a wi-fi connection:
  1. No connection available
  2. Poor signal strength
  3. Wi-fi on device not turned on
  4. Faulty wi-fi driver in device
  5. Using wrong wi-fi security password
  6. Router has your MAC address blocked
  7. Faulty wi-fi module in device
If you can give specifics on what you have tried and what the results are we may be able to narrow down the possibilities.
Oct 25, 2015 | Computers & Internet
Tip
Problem in turning on some applications program signal in laptop
refer to the manual there are list of commands that will help you to activate your wirless signal...
make sure your router has turned on its wi-fi...
sometimes laptop has a quick button to on their wi-fi but some uses combination likes key "fn" + function key F1to F12
that's why you need to read the manual,..
hope its a help..
on Feb 06, 2010 | Computers & Internet
Turn on my wireless wi fi on my lap top saying my lan in os is off
On many laptops, there is an external switch to turn the wi-fi on/off. This is normally found on the front or sides of the laptop case. It can be easy to turn off the wi-fi accidentally if you grab your laptop a certain way that causes you to press the switch.
On some laptops, you will find the wi-fi on/off switch by raising the laptop screen to expose the keyboard. The switch may often be found by looking at the area above the keyboard. In almost every case, the wi-fi on/off switch will be lit if the wi-fi is on, and unlit if the wi-fi is turned off.
Feb 28, 2015 | Medion Computers & Internet
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
Cannot turn on wireless lan with fn+f2 keys
1. first turn on the "wi-fi/wireless" switch on ur laptop manually.
2. now use the key combination for wi-fi/wireless
3. if it still not working, reinstall the wi-fi/wireless driver again, and restart ur system
Jan 01, 2010 | ASUS F6A-X2 PC Notebook
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Cant turn on wireless capability
Press the Fn Key and then while holding it down press F1 key. There will be a pop up box come on screen, click wifi enable and ok.
Its that easy.
Sep 02, 2009 | Computers & Internet
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
Aug 26, 2009 | Everex StepNote NC1502 Notebook
Linksys Wireless-G WRT54G Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
