Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Nikon 18-55mm lens is stuck , even when not on camera how can i fix it
  • 1 more comment
  • jadalyn Aug 17, 2008
    Lens will not zoom in or out, it is stuck on 55 and will not budge, as if it's locked onto 55mm.
  • Anonymous Dec 19, 2008
    The focus/zoom guides are misaligned i took mine apart...I don't ad vise!!! and noticed cheap plastic inner lens was tweaking the metal guides so i removed the outer metal guide and bent it back into place. it worked 4 a month and then got worse!!1
    Just buy a better lens.
    K-doubBle
  • kellieb67 Feb 08, 2009
    my Nikon 18 - 55 lens that I've had for a year and half is also stuck on 55, on and off the camera. worked one day and the next it just stopped -no reason ? after reading posts by others with same problem I'm just going to take mine in for repair.
    Problem Solver:
  • 14 Answers
K-doubBle
Posted on Dec 19, 2008
  • 78 Answers
By "stuck", I'm guessing you mean the focus. Flip the switch on the lens from 'A' to 'M' if it is.
If the lens won't zoom, hand it over to your local camera lab for repair.
Posted on Aug 09, 2008
4 Suggested Answers
  • 11967 Answers
SOURCE: camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
  • 11967 Answers
SOURCE: My Nikon L18's lens is extended half way and
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Posted on Jul 19, 2010
Jimsta01
  • 405 Answers
SOURCE: my digital camera has a lens error
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jul 24, 2010
Camera lens is stuck in open position and even if I remove the batteries and replace them, there's no activity whatsoever. Any advice would be greatly appreciated.
This is a problem you will not be able to fix yourself. Contact the Nikon USA repair depot nearest you for a repair estimate. Go to the Nikon website for the closest one. Once you have an estimate, you can decide if it pays to have it repaired. Remember, prices have come down since you bought your L110.
Apr 05, 2013 | Nikon Coolpix L110 Digital Camera
My nikon lens af-s DX NIKKOR is stuck won't turn
The lens and housing will probably need to be replaced, but I would take it to a camera repair shop and have it checked to rule out other problems before proceeding with repairs.
Jul 03, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
I have a Nikon D3000 SLR. My lens zoom should range from 18-55mm but for some reason it won't go past 24 (so is stuck from 18-24mm) I have tried everything to fix this, including changing settings and...
Whatever you do, don't force it. Unlike your camera, which has just a 1 year factory warranty, Nikon lenses are warranted to be free from defects for 5 years; and is likely still under warranty.
Contact Nikon Service to have the lens properly serviced / repaired. Having it looked at by an unauthorized repairer or even "messing with it" yourself could void the warranty.
I hope this helps! Please rate my reply - thanks!
Dec 18, 2010 | Nikon D3000 Digital Camera
COOLPIX P80 Digital Camera: my nikon camera's lens is stuck...
The lens of the camera can be retracted by mechanical means driven by gears thus sometimes likely to become misaligned or jammed. Please do not attempt to force or push the lense as it might cause serious damage, the best thing to do is to have it fixed by your authorized local repair shop and have the mechanical components checked.
May 17, 2010 | Nikon COOLPIX P80 Digital Camera
Nikon Coolpix Lens Error
Hi!
It could be focus system problem - most likely stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Sep 26, 2009 | Nikon Coolpix S210 Digital Camera
When I press the on/off button to open my camera a message appears stating 'Lens error' and the lens automatically opens and closes a couple of times before closing so I cannot take any photographs. How...
Hi!
Most likely the focus is stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Tom
Sep 23, 2009 | Nikon Coolpix S210 Digital Camera
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
How can i repair my D60 Nikon lens? It wont zoom in or out ?
Sounds like its damaged, if the zooming is stuck. It might have fallen causing internal parts to damage.
I strongly recommend contacting Nikon service for this kind of repairs, because its far too easy to trouble the glass if you open it. I mean even if you manage to fix the issue many things can go wrong inside and the lens wont be come out clean. Better to leave it to professionals here.
Ruchir
Aug 13, 2009 | Nikon D60 Digital Camera with 18-55mm lens
How can i fix a stuck lens on a Nikon COOLPIX L11?
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 13, 2008 | Nikon COOLPIX S200 Digital Camera
Nikon coolpix p50, lense error, camera won't work lens stuck.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
1,176 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
