Question about Ovens
Wiring of an old GE/Hotpoint Oven
Hi there - I am re-doing an old 1920's(?) cooktop. I first took it to the best appliance place in town - they did not do a good job on it at all. It worked, but barely.
When I got it back from them, we replaced both the bake and broil elements of the oven and everything worked pretty good, except the oven wouldn't preheat. I then had the old burner section removed and replaced it with a new gas cooktop (works great!). We had to disconnect the oven and all the wiring to get the gas cooktop mounted onto the stove body. Now I am trying to re-wire the oven and am flunking badly!
The old oven had a oven thermostat knob asembly (with the sensing probe that went inside the oven and a standard knob to adjust the temperature), a selector switch and a thermostat regulator with a wheel on the outside of the stove. I think the appliance repair firm disconnected the old thermostat regulator and just put in a new oven thermostat assembly, because of the phillips screws in the selector switch and the oven thermostat.
So... now to my questions:
  1. I cannot use the original thermostat regulator that came with the stove (it is right over the stove burner), shouldn't the oven work with just the selector switch and the oven thermostat assembly?
  2. While I thought I was super careful to mark all the wires, nothing turns on when I wire it. I have used the OHM meter and everything seems to check out, so I might have mis-connected the wires somewhere. How do I know where the wires go? There is no wiring diagram that can be read - it is too faded. Right now, the red and black wires from the power source are going to the oven thermostat assembly. The terminals are numbered 1,2,3,4. A yellow and a blue wire go from the thermostat assembly to the selector switch. The selector switch has 7 terminals - B,C,X,W,Y and two unmarked. One wire from the bake element goes to B, one wire from the broil element goes to C, and two blue and yellow combined wires (from the bake and broil elements) go to a single unmarked terminal. The X is emply, the W has a blue wire going to the thermostat, and the Y has a yellow wire going to the power source. The last terminal is unmarked and it has a yellow wire going to the thermostat. Does this wiring set up make sense? This is now I marked the wires.
  3. When I was disconnecting the thermostat from the front of the stove, the piece fell - Does the copper wire wrap around the piece that turns?
Thank you for any help you can provide - I really need it.
SOURCE: replace upper grill element in a old GE wall oven
Replaced selector switch...problem solved.
Posted on Dec 05, 2008
MNTECH
  • 1543 Answers
SOURCE: GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Posted on Dec 14, 2008
SOURCE: JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Posted on Jun 21, 2009
  • 31 Answers
SOURCE: I have a kenmore electric stove/oven model
You probably know this, but on an oven unit there has to be two different phases of 120 to make it work. Check the wires that attach to the oven unit to make sure that you have 240 when in oven mode. If you have only 120, find out which wire is not hot and trace it to its source. Is it miswired at the other end? Is it shorted to one of the broiler wires? Usually there is a schematic to show how the oven is wired. Check for anything that is common to both oven and broiler wires and make sure the wires are on the right terminals. With out seeing the sove it is hard to know what it going on. Hope that helps. Robin
Posted on Jun 10, 2010
  • 906 Answers
SOURCE: Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Why is oven door locked and won't open?
Troubleshooting a GE Oven That Can Not Get Out of Locked ...
motherhood.modernmom.com > Around the House > Home Appliances
Self-cleaning GE ovens have a locking oven door as a safety feature. ... How to Troubleshoot a GE Artica Profile Refrigerator That Won't Get Cold ... Allow the oven to cool down if there is food inside the oven, and unlock the door once the ...
Oven won't open!!! [Archive] - Chronicle Forums
www.chronofhorse.com > ... > Off Topic
The Chronicle of the Horse
Dec 25, 2010 - 100+ posts - ‎100+ authors
Different ovens unlock at different times, some are by temp and some are ..... -cooktops/19645-ge-oven-door-wont-unlock-after-self-clean.html)
Dec 30, 2015 | GE Ovens
How do you replace main oven temperature indication light for hotpoint double oven cooker model ew 74
In doing a general google with the brand/model, there are many things that come up about issues. You need to contact http://www.geappliances.com/service_and_support/contact/form_email.htm. They state their product is backed by GE. Many places sell this, but look for one with GE products. You might have an appliance store close by with that information.
Mar 06, 2014 | Ovens
I need to replace a switch(dual infinite switch) on my kitchenaid oven (YKERC607) but I don't know wich wires go where. Could someone help me? Thank you un advance. Mathieu
An instruction booklet should have come with the part, but if you didn't mark or label the wires when you took them off the old switch, then you have to identify them by whatever method is available. Appliance Dealer repair shops usually have microfich or computer schematics to identify parts and their assembly, and you might try to call on one of these places, if you can. They're usually more than happy to bring up the diagrams and try to assist. Other than that, one would need a full fledged service manual, and other than being difficult to find, they're usually somewhat expensive, but not always. Here is a great link to a site that has some good information about appliances, and they do have your parts, and may be of assistance to you since they also have instructions for the parts. They may be able to email you a scan of the instructions, never know till you try...so contact them. Here's the link:
http://www.repairclinic.com/Brands-We-Carry
Good luck, hope this helps, and thanks for using FixYa.
Aug 27, 2010 | Ovens
I need a wiring diagram for the replacement ERCU on the JKP27WW1WW oven. Our oven is from 1994 and the new 'clock' module (ERC3) is slightly different where it connects to the 'bake' and 'broil' contacts....
I am not sure if this will help you but I did find a fellow that says he has the adaptable diagram for an updated part on this forum :
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15496-wiring-diagram-oven-control.html
Oct 30, 2009 | GE JKP27 Electric Double Oven
I have a 10 year old GE profile dbl wall oven that I love BUT with a new Stainless fridge, cooktop and dishwasher the wall of white oven is a glaring mis-match. The oven doors both have exterior white...
Go to www.applianceart.com and check out their instant stainless material which is perfect for refacing your existing appliances and getting the stainless look you want without the stainless pricetag.
Contact these guys with any questions you may have.
Oct 18, 2009 | GE Profile JTP56 Electric Double Oven
How do i replace the cooktop light bulb in my microwave oven?
I realized the light bulb was fixed using an adhesive (maybe a glue stick) that is why, I had a hard time removing the old bulb. After forcing it (and breaking the adhesive seal) I was able to replace it with a new one.
Oct 06, 2009 | GE Ovens
Dead trivection oven by ge JT9300h1ss
This model has issues with the power input controller board, usually caused by surge following a power failure... board is $285 from GE plus $90 or so to install after paying a $100 service call. Replacment part is special ordered and generally takes a week or so.... have 2 of these ovens... ask me how I know.... LOL
May 30, 2009 | GE Profile JTP18 Electric Single Oven
Need heating element for old Hotpoint built-in oven
Midwest Appliance Parts
2601 West Diversey
Chicago, IL 60647
1-800-621-1932
- Toll Free
1-773-278-1300
- Local
Supply a wide range of hotpoint oven heating elements
Apr 11, 2009 | Ovens
LGR3330ADB Admiral touchpad display does not work
Usually this is due to a bad main clock/electronic control in the control panel but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru --- www.repairclinic.com
https://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 27, 2009 | Ovens
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Ovens Logo
315 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
