Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
Have one that does not work and want to know how to open it- can see no clear idea how to and want to avoid damage. regards, Peter
  • 4 Answers
The mixer is not designed to be disassembled or serviced. When it breaks (and it will) Sunbeam will replace it under warranty if you are lucky or you toss it in the trash.
That said, start by prying out the beater release button. There are two small screws under it and one between the beater inserts to remove the chrome front cover. The large black dial at the rear can be pulled straight off, revealing more screws. The motor and drive assembly in the top cannot be removed without disconnecting wiring from the circuit board in the base.
Posted on Dec 16, 2008
Housing unit
That is usually caused by a stripped gear. It is hard to give you a good idea of what to check without a model number.
If it is a 4.5-5 quart regular mixer then it will most likely be a bad worm gear:http://www.mendingshed.com/kawormgear.html This would be a fairly easy repair. You will also want to check the other gears to make sure they are not damaged.
However if it is a 5 or 6 quart Professional mixer it will be more involved than that. You will want to take the mixer apart, inspect each gear (you will need to clean off the grease). Any gears that are worn damaged or nicked will need to be replaced. Also check the bearings, and the retainer pin. If these are bent or damaged they may need to be replaced. While you are in the mixer check to see if the transmission housing is cracked, if it is replace it with the new metal housing. If all of the above are in good shape check your planetary assembly, it is pressed together and could become loose causing the same issue.
Please let me know if you have any questions.
Apr 22, 2013 | KitchenAid Food Mixers
Commercial kitchenaid mixer will not switch on? I have replaced the amp on the plug and carbon brushes (putting them in the correct way) and still not joy. Any ideas about the problem? I was given the...
Yes i would open the back cover and try the adjusting screws on the speed control plate, I have repaired several mixers just by turning the two top screws a quarter turn counter clockwise or just the bottom one a quarter turn clockwise.
You will have to check the plug it may be damaged and make sure your wall outlet is working and not operated by a wall switch that may be turned off. seems silly I know but check anyway. let us know if this helped, there are other things to check but i would start there first
Mar 30, 2013 | Food Mixers
I have a Sunbeam Mixmaster 2351 Heritage Series that the speed dial control numbers fade. Sunbeam replaced my mixer but want to prevent the same problem for reoccurring, Any suggestions?
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Feb 15, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Hi bought an a200 mixer it fell over when gettin it out of van now doesnt work at all nothing any ideas
May have damaged the start switch in the back of the motor. Check www.hobartservice.com for your local Hobart office.
Mar 18, 2011 | Hobart A200 Stand Mixer
Does this machine ever need grease or oil?
No! Typically these are permanently lubricated at the factory.
Unless an expert that does repair work on this type of machine comes in and says something different. I would avoid opening this machine up and adding any kind of grease or oil. It may wind up in your next cake! :)
Oct 03, 2009 | KitchenAid K45SS Classic Stand Mixer
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
Can opener
Hello .
if you want assemble can opener to your A701A
the model is : A778
please visit our web site Kenwood Chef Restore in the section download, you find the compatibility of the attachment to download.
also Download in the same section the instruction book for A701A models and there explain how you fit the can opener and another's attachments
regards
Dec 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood chef model 781a
To open take off the top and open the three screws. Use light grease.
Jul 01, 2007 | Kenwood KM800 Major Classic Stand Mixer
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
449 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
