Question about Yamaha AX-596 Amplifier
Matching book shelf speakers for yamaha ax 596 amplifier
Could you please suggest a pair of matching book shelf speakers for yamaha ax 596 amplifier
  • 2,071 Answers
Just click to choose;
NEW iBALL BOOSTER 5.1 SPEAKERS WITH MANUFACTURER WARRANTY
The iBall Booster is a high quality 5.1 speaker system with complete wood encased speakers. Gives... control...
FREE 350 WATT AMPLIFIED SPEAKERS Creative Inspire 5200 5.1 Multimedia Subwoofer Speaker System With 1 Year Warranty
hope this may help;
Regards,
VOTIT
Posted on Jul 29, 2008
Yamaha AX-596 bass & treble control panell not working
Make sure there is no tone bypass button if it has one.
Apr 26, 2014 | Yamaha AX-596 Amplifier
No volume
You need to check the settings and also check the connection from receiver to five speakers .
Oct 28, 2008 | Yamaha AX-596 Amplifier
When turning the source selector on my AX-596, is sometimes takes a couple turns for it to change source. Is this an easy fix? dirty switch?
remove the front panel and if you have clear alcohol and just few times over the SW and turn it around that's all
just tell me if it work
Aug 03, 2011 | Yamaha AX-596 Amplifier
I have connected my yamaha amp with my tv and blu ray player. when i am playing a movie, the sound is coming out of the speakers but when i am watching the tv no sound is coming out of the speakers.
hi,
Do one thing get a stereo RCA cable and connect its one end to the audio output of your tv and other end to the any one of the analog input of the amplifier. when you watching the tv simply select the corresponding input in your amplifier to which you have been connected the RCA cable.
Also there is one more why if the tv has an optical output. connect the optical out put of you tv to any of the optical input of the amplifier. select the corresponding input when you watch the tv
ok
Feb 14, 2011 | Yamaha AX-596 Amplifier
My Yamaha YHT-791BL amplifier goes off every time I turn it on. How can I fix it?
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Its usually not a fault that you will see unless somethings burnt up. This is solid state electronics and you dont see this stuff go bad. But in the meantime try disconnecting the speakers and see if it still goes into shutdown and at the same time have a dc multimeter attached to the speaker outputs. If the unit comes on and you dont see any DC at all or very very little B+ on both speaker terminal sets then you may have a defective speaker. If you do see dc then thats why the protections comming on so you dont blow out your speakers.
Also check for cracked solder connection.
Good Luck
May 26, 2010 | Yamaha AX-596 Amplifier
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
I have a blown channel and would like to order the
I would suggest buy the service manual first
www.stereomanuals.com
or
www.manuals-in-pdf.com
Then you can find out which parts and what numbers
Apr 19, 2010 | Yamaha AX-596 Amplifier
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
Yamaha amp ax-597
Happy to help, just need to hear from you mate. Cheers
robotek
Aug 29, 2008 | Yamaha AX-596 Amplifier
Yamaha AX-596 Amplifier Logo
422 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
