Question about Frigidaire PLMV169DC Microwave Oven
Does not work
Completely dead,
outside fuses checked
  • Frigidaire Master
  • 9,098 Answers
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Please write back with your brand and model number if you need further help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
My magtag over-the-range microwave (Mmv4205baq) is completely dead. It's not very old, can it be repaired?
It's probably the internal fuse.You will have to take the microwave down so you can remove the housing to get at the fuse.(I will probably install an accessable panel mounted fuse holder if this ever happens to mine-already did it on the little microwave I carry around on my work truck to heat up my lunch).
Dec 17, 2012 | Maytag MMV4205 Microwave Oven
Won't operate
see this steps and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Oct 15, 2012 | Panasonic NN-T964SF Microwave Oven
My Panasonic The Genius microwave just stopped working not getting any power to display. Wondering if it is the fuse and where that would be located.
HI, if this unit is totally dead, this may be a power inverter issue. there is a fuse located on this board inside the unit. you will need to gain access to this board and fuse by removing the outer cover. there should be a few screws on the outside of the microwave to remove.
Check the In-line fuse for its value. if the fuse is good, replace the power unit(inverter board)
Jun 20, 2009 | Panasonic Microwave Ovens
My microwave doesnt work at all
If the micro is completly dead and the outlet is OK... check the main fuse inside the cover. Unplug unit, remove cover (screws in back) and check the fuse where the power cord comes in through the back.
I am not sure what region you are in but in the States it is usually a 15A fuse. REPLACE ONLY WITH EXACT FUSE. Most hardware stores have these for microwaves.
MM85
Jul 22, 2008 | Frigidaire FMT116E1W Microwave Oven
Microwave
You may have a blown internal fuse. While I would recommend that you take the unit to a qualified repair center, you can do a little troubleshooting on your own. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement fuse at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
If the unit does not come back on, then there is a possibility that the unit's power supply has failed.
Please let me know if I can be of further assistance to you.
- Jim
Jul 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Dead Microwave Oven
Remove the top cover of oven, there should be tec screws on the bottem of unit to remove the cover, check for bad relays,fuses and fuseable links that could have finaly gone bad.
Jan 13, 2008 | Maytag MMV4205 Microwave Oven
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Completely Dead
Since you've checked the external supply, the most likely causes would be the internal fuse, thermostat or thermal cutout. You can find exploded views and order parts here: http://tinyurl.com/gv383 For safety tips and disassembly tips, you can see my site via my listing here on FixYa: http://tinyurl.com/yzjozk
Jan 30, 2007 | GE Advantium SCA2000B Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
115 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
