Question about Celestron Advanced C102-HD (241 x 102mm) Telescope
Hand controller not working
Hand controller unit dropped form my hand with no visual damages seen from out side. But it no more drives the telescope though while connecting with the battery pack the middle light (supposed to be in green during sidreal movement) is on in yellow mode.By touching the motor I feel the pulse that the controller delivers to the motor but very unfortunately it is not driving the telescope. Can you provide the circuit diagram? I've purchased this telescope last year from Adorama and brought in India this year.
Biswajit
  • 3,185 Answers
You have broken something inside the hand controller-- the computer is in the hand controller NOT in the telescope. Contact Celestron for a replacement hand controller or advice.
http://www.celestron.com/c3/page.php?PageID=37
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Posted on Jul 09, 2011
Why does the hand controller light up then goes dead
Possibly poor connection to the scope. Known issue. Go to
Weasner Mighty ETX Site for tips on repair
May 25, 2014 | Meade 494 AutoStar Telescope Control Unit...
Meade autostar powers motors only no other functions
Do a RESET on the hand controller and then re-enter time date and site--
If this model has a Calibrate Motors feature in the hand controller do that also.
You must have fresh batteries in the scope or the controller will have very strange errors when the battery power drops below about 60% of full charge.
Sep 13, 2011 | Meade DS114-EC Telescope
I have a DS-2000 Series Refracting telescope, it will automatically go up and down with the hand held computer, but will not move side to side.
You DID tighten the clutches-- and you do have fresh batteries in the scope?
Either the hand controller buttons are broken or you have some kind of damage inside the scope base-- or a blown circuit board on that motor.
Sep 05, 2011 | Meade DS2130ATSLNT (296 x 130mm) Telescope
It lites up for 1second than goes out, the light on the tri-pod stays lit ?
Either the hand controller is broken or the hand controller cable is broken-- or you habve OLD batteries in the scope.
Aug 29, 2011 | Meade 494 AutoStar Telescope Control Unit...
I dropped by LXD -55 autostar handcontroller and now the display won't light up and if it does the backlight is so low I can't read it. Can it be saved or do I have to buy a replacement?
Buy a replacement, You broke something inside the hand controller. Possibly the screen ribbon cable was jarred loose a little. After you get the new hand controller, carefully open up the hand controller and make sure the internal cables are all secure.
Oct 06, 2010 | Meade LXD55 Telescope
Is there an user friendlier hand controller available for the Ultima 2000? Does the wedge make much of a difference?
The wedge is only used if you take astro-photos. You do not need it for visual observing.
Contact Celestron support about the hand controller here:
Sep 29, 2010 | Celestron Ultima 2000 -- 8 Telescope
Celestron Nexstar 114gt telescope,hand controller lights up only
Do you have a fresh set of batteries in the scope? Better to use an outside 12 volt power pack with the Celestron 12 volt "cigarette" lighter cable.
This can be three things:
Low power
Bad cable from hand controller to scope.
Or a broken hand controller
Try fresh batteries first.
Dec 31, 2009 | Celestron Optics
Celestron CPC 800 frozen display in the Hand Controller
I've seen a couple of things cause this problem. Both can probably be fixed by you.
The first thing to try is to look at your power connector on the telescope. You'll see a pin sticking up with a split in the middle. Take a small knife or screwdriver and very gently pry that **** slightly apart. I've seen where that compresses and it becomes intermittent.
The other thing I've seen is an intermittent connection between the hand controller and telescope. This can happen on the controller end or telescope end. The AUX ports will work for the hand controller too. Try it in those ports and see if things improve.
If they don't, then you could have a loose connector on the hand controller. Mine was bad enough that if I wiggled it the controller would either go blank or lock up. I fixed mine by getting a telephone crimp tool and crimping it. It's worked fine since then.
You may also wish to check out the CPC group on Yahoo Groups.
-jodair
Apr 02, 2009 | Celestron CPC 800 Professional...
Meade autostar hand unit fails after 2 seconds changed hand units
You damaged the circuits inside the hand controller-- unless you are an electronics whiz these cannot be repaired.
However you can find them for sale directly from Meade and on Ebay (used) usually for about $80.
Mar 04, 2009 | Meade 494 AutoStar Telescope Control Unit...
Celestron Advanced C102-HD (241 x 102mm) Telescope Logo
171 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
kenneth njonjo
Tony Parsons
Tony Parsons
Are you a Celestron Optic Expert? Answer questions, earn points and help others
