Question about Sharp Televison & Video
Pink tint problem with a sharp T.V
My uncle fiddled with the settings on our T.V and somehow managed to change the tv setting so it has a pink tint, i cant figure out how to fix it. there is no remote or manual for me to use or refer to. in the 'picture' menu the word tint is there, in pink. it gets skipped when i scroll, so i cant select it. Any Ideas?
Jodie
  • mistys_sweet Jul 28, 2008
    i tried that.. but it only switches between pal and auto.. Grrrrrr!!!
  • Nic M Jun 19, 2012
    Anyone found a soultion to this as I have exactly the same problem!? And the solution below doesn't work. Does it mean the picture tube is going bad or what?
  • 10,594 Answers
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Posted on Jul 27, 2008
Entire screen has a pink tint. Can change to blue with settings. Cannot change to natural with tint etc.
Check that all cables are intact and plugged in correctly.
Turn of the TV completely. There might be a manual button on the tv for this. As the last thing, remove the power cord from the power outlet in the wall or where it is placed. Wait 1 min. Then put it back in, swith it on and turn on the TV again.
If this doesn't help and you have tried replacing the cable that you get the picture from (VGA, DVI, Antenna etc.) then it is most likely broken.
Jul 06, 2014 | Sceptre X400BV-FHD 40 in. LCD TV
TV Picture has a pink tint all over it & there is no green.
change your color setting on tv main board
please rate my answer
Jan 06, 2011 | Televison & Video
Pink hue to all photographs taken on screen and print
You may just have the white level set wrong or the camera in the wrong mode than what you are epecting.
You should be able to reset or set that from the setup menu.
Mar 23, 2010 | Sony Cybershot DSC-T200 Digital Camera
16 year old, 36'', analog TV, model CX35E60, with Charter cable service. The picture has a pink tint when first turned on. The pink tint lasts several minute and then will correct and the picture will be...
Your picture tube is on its last leg. Best enjoy the old girl while you can. This would be way more expensive to repair than it is worth if you can still find a tube for this set. That has been a good set to last that long. Not too many of them left out there. Thanks for using fixya.
Nov 09, 2009 | Toshiba CX35F60 35" TV
Pink tint
your va and vs on power supply need to be adjusted but you have to know what your doing to set it right and requirs a volt meter
Jan 16, 2009 | Samsung SPN4235 42 in. Plasma HDTV
I have a 60" SONY VIDEOSCOPE KP-53V15 the person that i received it from said that the picture sometimes turns pink tinted (the best wasy I can explain this) ... Where things on the screen should be white...
In the back of set you have a red green and blue gun.
two or three problems with sony on this.
sum times the green gun will go intermit.
by gentely taping the neck of green gun while set is on, and you see corection, you need to replace green gun.
in others we have found bad soldier in the HV section of the flyback.
and sumtimes its due to louse conectors going to the HD input in back of the set.
hope this is of help to you.
regards,
daniel.
Jan 15, 2009 | Televison & Video
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Canon powershot S410
a pink tint CAN be removed in Photoshop or picasa.
Check the settings in your camera. it could be set to "sepia" under effects.
Jul 23, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
PT-47WX49 - Pink wavy horizontal lines
Try doing a reset of the TV first. On Panasonics this is done with the TV on and then pressing on the POWER and ACTION (on the fron of the TV only) buttons at the same time until the screen blanks out or a diagnostic screen appears. Once you do this all custom functions (color,tint,channel memory) will be back to factory defaults.
Feb 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
561 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
