Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit IDL40 Dishwasher Fault
Hi
I currently have a fault with the above dishwasher where it runs through the first part of the wash cycle but then stops and flashes lights 1 and 2, how can i fix this issue as the wife is getting sick of washing up!!!!!!
Thanks, Dean
  • 7 more comments
  • shawpinklady Aug 01, 2008
    hi mine keeps tripping the electric just after it has tried to put some water in it, i have blown the waste pipe and sometimes it goes throught and bubbles come out of the machine and other times i cant get any air down the pipe, i have filled it through the waste pipe with hot water trying to clear it but it still keeps tripping the switch. can you suggest anything else as i thought it was blocked but then it drained out, it did fill through the waste pipe and now it wont. cant get to the end of the pipe in the machine without taking all the bottom off or can i?
  • Anonymous Nov 30, 2008
    Just happened, this the problem you have with easy single push function buttons, no way of knowing what fault is. Still no conclusive answer to the first two lights fully on tho? any ideas?
  • rick101b Dec 14, 2008
    I have the same problem - the first two lights come on. I suspect that there is a blockage somewhere because the water in the machine doesn't drain. The filter seems pretty clear, so I need to investigate further. Someone else suggested that the issue could be a blockage in the pump. This seems a logical conclusion - I will check this next.
  • Anonymous Jan 06, 2009
    Same problem. Won't drain and flashes lights 1 & 2.
    Faultfinding section of the Indesit manual gives meanings for several combinations of flashing lamps, but not this combination! Fault started about a week after one-year gurantee ended!
  • paco237 Feb 23, 2009
    anyone have any solutions to the non draining of the water and flashing 2 lights?
  • batgirl32 Mar 03, 2009
    Mine starts normally (I put it on cycle 1), and then stops on cycle 3, without completing the full wash.
  • Anonymous Apr 26, 2009
    same here, starts cycle then stops and bottom filled with water. how do i drain it and what are the flashing lights! Seems like indesit not that great after all!
  • seventytwo May 04, 2009
    Same thing has happened to me...i have only had the washer 2 weeks...have called out the engineer so will post the solution when i get an answer
  • george wood Mar 31, 2013
    mine 2 can any one help
Pump blocked
Posted on Jul 28, 2008
SOURCE:
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Lights 1 and 2 flashing indesit IDL40
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Jan 11, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Jun 26, 2011 | Indesit Dishwashers
Hi, our Indesit IDL500 dishwasher has stopped working. The fault light 2 is flashing. The manual doesn't mention what fault this indicates. Any ideas. Cheers, Neil
Hi Niel, If you were to start the cycle from the beginning, where in the cycle does this occur? . So many code numbers for so many units, hard to keep up .Just note if heating is taking place and if drainage is correct. Hear from you soon.
Sep 26, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
IDL40 only washes in cold water now.
YES IT SOUNDS LIKE IT'S THE ELEMENT OR MAYBE A WIRE HAS COME OFF THE ELEMENT FROM VIBRATION,
May 29, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
from indesit website http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
Mar 25, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Feb 23, 2008 | Dishwashers
Indesit D61 Dishwasher element fault?
poss element or heater relay on the pcb.
Jan 19, 2008 | Indesit 24 in. D61 Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
2,638 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
Paul Bade
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
