Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint aquarius wd440g washer/dryer
My washing machine wont spin its making loud noises and reduce creases and dryer light is flashing im sure something is wrong with the spin!! Please can someone help because i cant afford to get it repaired and all my kids washing is inside it!!! Claire
  • adrianhyde78 Dec 07, 2008
    Does this mean the pump needs replacing or will clearing out the machine fix the pump?
  • mackenzie77 Jan 07, 2009
    how do you get the pump open?
  • 57 Answers
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Posted on Jul 28, 2008
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
205 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
