Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. If it fails, then try to remove the battery for at least one hour. click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password or You need to prepare: hope it helps. don
Ebay you can purchase a
Password Unlock/Recovery For Windows 2000/XP/Vista/7
Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7
Buy It Now price: US $1.49 (Approximately AU $1.50)
also
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
DO NOT panic! You definitely have 100% chances to enter the locked computer withn several minutes.
Windows Password Recovery software is the tool that you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK!
Hi,dear. The simplest way to reset your password is by using the windows password unlocker tool.
