Question about RCA P52926 52" Rear Projection Television
Samsung LE26R7 TV not coming on
I switched of my TV from the mains, and the next day, the TV is not coming on (no standby light)
Just did a blog post about our Samsung not coming on -
http://wp.me/pbi5z-2Vj
Posted on Mar 20, 2010
    Champion:
  • 230 Answers
Check for main fuse open 4amps. Maybe pwr supply is going. Other possible thing Horizontal transistor ( short) stop run B+. Thank you
Posted on Aug 13, 2008
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
LCD LE26R7 won't turn on after switching off
This is almost certainly a bad main board and it will almost certainly need to be replaced, not serviced.
I'd google for "LE26R7 main board" - check on eBay as well - but frankly if all you have to do is re-plug the TV in order to watch it I'd probably recommend sticking with that.
I predict there won't be a quick fix to this problem other than replacing the main board.
Don't kill the messenger :-)
bobby @ coppelltvrepair . com
Aug 25, 2012 | Samsung Televison & Video
Samsung 55" flat panel lcd tv is not coming on the standby button light stayes on but no picture coming on it doesn't come on with the switch only by plugin it to the outlet.
Does the backlight come on? or even flash on and off when the TV is switched on? I presume the standby light is showing 'blue' then. Do you have any sound? Also, when the TV remote is pressed, does the standby light flicker?
Feb 22, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Trying to retune Samsung LCD TV LE26R7 but settings (4th option on menu) is greyed out and won't let me access to retune was okay before sept 30th
HI,this might just help!...
1.press D.MENU on youre tv remote
2.scroll down to SYSTEM
3.access the RESET function
4 enter 0000
5 follow on screen instructions
TV will then wipe all existing channels and start from scratch.
worked a treat on my SAMSUNG LE26R7........However i noticed my signal strength dropped significantly!!...obviously them at the other end (digital tv boffins)have been mucking about,A bit of fiddling about with my existing arial did the trick!!
REGARDS.......G WATSON
Oct 02, 2009 | Samsung Televison & Video
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
TV will not come on via the remote control and remains in standby
Try switching it off at the main switch on the TV. Then switch it back on from the same main switch on the TV. If the TV then comes on & works normally, then check the batteries in your remote control, they may need replacing.
Mar 28, 2009 | Samsung LE32A41B 32 in. HD-Ready LCD...
Samsung tv wont come out of standby
Not expensive but very hard to find the exact problem.
Both are not the same problem.
Mostly, your case related IR module problem.
the other below, yours are poewr board or thermostat problem.
Jan 14, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
166 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
