Question about Pioneer VSX-D710S Receiver
Component assignable outlets
I have connected a new HDD/DVD to my Pioneer VSX D710S amp. Via the component (assignable) digital points.
It does not show on my plasma. However if I connect the leads from the HDD/DVD direct to the Plasma it works.
When connecting to the assignable points, do you have to do something else. or program it???
  • Anonymous Nov 20, 2008
    when i connect my dvd to component assignable outlet like coaxil, or optical in and i chage in front panel signal to digital it does not give any respond no sound also through analog i do not have any problem, is it a fault of the receiver or any other settings. other than signal select
  • 2,071 Answers
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Pioneer VSX-D710S and the message SP off and DTS off message appear and I have no sound. Any ideas how to turn them back on?
The SP off message is the setting for turning the speakers off while headphones are connected on some Pioneer models. If yours is one such model, hold down the RECEIVER button and press the SPEAKER (text may be written above another main function) button on the remote simultaneously and the sound should return.
Apr 01, 2010 | Pioneer VSX-D710S Receiver
Hello,I have a Pioneer VSX-D710S 5.1 reciever get hot and smell l
Heatsinks on mosfets are probably not connected, or broke connection. If you are not trained in electronics dont go poking and proding around in there, a capacitor can easily kill you. If you have some knowledge open it up and see if you see and burnt components etc. You may just need new heatsink grease etc. Does it have a fan that stopped working? If a piece is visually fried take the unit to your local electronic repair shop and see if they can solder in a new part if available. depending on the price of the amp, it would be ebetter to go spend money on a new one.
Jun 03, 2009 | Pioneer Audio Players & Recorders
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Nov 16, 2007 | Pioneer VSX-D510 Receiver
Pioneer VSX-D710S Receiver Logo
210 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
