Corrupt bios - Computers & Internet
Wal-Mart carries those batteries also. I got one yesterday for $3.50. Or two for $4.65
Posted on Nov 02, 2009
  • 27 Answers
First, replace the battery as you were advised in the previous solution. The when you boot up the computer go into the bios and reset the time there. To go into the bios you will press either the delete key when it boots or the F2 key. You may even see a prompt when you boot up as to which button to press. Then be sure to save the changes on exit. Sorry I can't help with the drivers issue. Not enough info to work with.
Good Luck!
Posted on Jul 29, 2008
    Sergeant:
  • 329 Answers
If your battery is going bad, that onmost computers can be replaced by anyone. Open the computer (un plug the power) and you will see on the mother board the battery. It is about the size of a quarter and about that thickness also. There are usually some kind of small tabs that hold the battery in place. Get the number and go to almost any store and buy one, usually less the $ 5.00. Pry out the old one and install the new. Plug in and set the time, see if the machine keeps the time.
As for the devices, What are they? If you are running XP or vista, Get on line and downlaod the drivers if you can and store them on the desktop. Go into control panel, System, Device manager and remove. Turn computer off and then on with the divices plugged in. Windows should find those devices and install the correct drivers if they are plug and play. If they don't install go in to control panel and add new hardware, find the device and try to install.. God luck
Posted on Jul 28, 2008
Bios real time clock battery is going bad and the correct time/date is wrong giving a bios error.
Another problem is any new devices were added but not configured correctly. wrong drivers!
How do you fix a corrupted bios?
I don't think it's corrupt bios, maybe a virus or malware.
But if you can go to the computers maker website and download bios and install them the way they tell you to install them.
Feb 01, 2016 | Computers & Internet
Boot Problem
I hope your laptop still can boot up from the DVD drive, so you can make a bootable DVD media with the BIOS flash (using other computer) to replace the current corrupted BIOS.
Feb 16, 2014 | HP ZD7168CL Notebook
Gigabyte bios rom error beep code
http://www.gigabyte.com/products/product-page.aspx?pid=3013#dl new bio here
Dec 03, 2013 | Gigabyte GA-EP45-UD3R Motherboard
Emachines notebook m5310 corrupted bios recovery
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
Flash an appropriate BIOS to the corrupt BIOS and reboot.
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at ftp://ftp.mrbios.com
Solution 4: (for Intel motherboards)
Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
Install the bootable upgrade diskette into drive A:
Reboot the system
Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
Turn the system off
Change the Flash Recovery jumper back to the default position
Leave the upgrade floppy in drive A: and turn the system on
Continue with the original upgrade
Oct 14, 2009 | Computers & Internet
ASUS P4S333 Bios is maybe corrupted
Asus motherboards are junk, if you buy another in the future, stay clear of Asus products.
With that said, you should check your system for malware and viruses first, before doing anything else
Sep 06, 2009 | ASUS P4S333 Motherboard
I lost the drivers and my bios is corrupted
yes you need to go to the manufactures website load the bios to a usb drive and flash the bios
Aug 21, 2009 | Computers & Internet
I have a corrupted BIOS (Intel 440BX motherboard) with Phoenix bios 4 release 6 (release no. 4S4.EB0X1.86A. 0011.P04). Cannot find the correct bios software to rectify the problem (even the bios software...
Hi, Read this information it might help you. Go to this web site www.hardwaresecrets.com/article/39/2 I hope this information will help you solve you bios problem.
Aug 17, 2009 | Computers & Internet
My bios is corrupted and iam not able to boot from it
I would only guess to reset CMOS and try updating BIOS from DOS. Altho, i couldn't remember for the life of it the process to update BIOS from DOS....sorry.
-Mike.
Jan 12, 2009 | Intel D845GVSR Motherboard
Computer will not boot after bios update
you updated the bios?
Its possible that your bios update failed and the bios is now corrupt.
try to rest the bios by th bios jumper, consult your manual or just remove the power and the battery for a hour and try again.
If the bios is corrupt it would need to be removed from the motherboard and reprogrammed.
Read this article
http://www.techarp.com/showarticle.aspx?artno=62&pgno=0
Apr 13, 2008 | EliteGroup MB|ECS 865G-M V5.0A 865G MB...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
