Question about 2wire (1000-400108-001) Router
HAVE 2 WIRE-LAPTOP WON'T SEE IP ADDRESS
I BOUGHT A REFURBISHED DEL LAPTOP-HAD TROUBLE SETTING IT UP FOR HIGH SPEED WIRELESS-A T &T TECHNICIAN CAME TO HOUSE TO HELP-HE GOT IT SET UP TO WHERE IT WOULD WORK ON HIS COMP. AND SAID MINE HAD SOME KIND OF PROBLEM NOT BEING ABLE TO READ IP ADDRESS-HE SAID REFURBISHER MAY NEED TO SEND SOMETHING TO INSTALL IN IT TO HELP IT.WHAT CAN I DO?THANKS
    Problem Solver:
  • 13 Answers
CONECT YOUR LAP DIRECTLY TO WIRE, PUT THE ADDRESS IN THE BROWSER http://195.168.1.254 & CHECK THE REAL ADDRESS IN THE LAPTOP
Posted on Jul 28, 2008
    Novelist:
  • 148 Answers
Greetings my name is Mark and I will be glad to assist you. Go to Inter net explorer and then tools then internet options then to connections make sure the box marked "always detect" is checked this should fix the problem. If it is and still will not connect write back and I will assist you further.
Be mucho blessed....Mark
Posted on Aug 24, 2008
Laptop says i am connected to internet but it won't let me online
Limited connectivity
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Nov 06, 2011 | IBM ThinkPad T40 2373 Notebook
Recently, i have received dir 615 route, it works on pc however, when i try to connect to my laptop it says limited access. p.s. i am using vista
Hi check if the same wireless name defined in your laptop if you have it go wireless setting remove the current name and try to connect , check the wireless encryption WEP or WPA you should have same setting for both Laptop and your router ,another thing u should check is make sure DHCP enabled on your router and on your laptop you should get IP address and DNS automatically also check the if you get any IP address it should be 192.168.0.* for your Router you can go to start type CMD then type ipconfig you will get the IP ADDress if you need more help please contact me on http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-625 (790069292637) Wireless...
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
Have install netgear range booster to wireless router but says limited connectivity
This can occur when the wireless adapter has trouble connecting to the wireless router.
It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
Feb 19, 2011 | NetGear WPN111 RangeMax Wireless USB 2.0...
I got a wireless router for a new laptop its hooked up but wont let me get online with laptop
check for the default ip setting of wireless router. If it is 192.168.1.1 then you need to change it to 192.168.0.1
to check the ipaddress of the router connect it with wire to laptop. at command prompt type ip config. look for gateway setting.. it will be 192.168.1.1
now go to internet explorer and type the gateway address 192.168.1.1
it will ask you for user name and password
enter admin as username and admin as password
now look for router ip address and change it to 192.168.0.1. save setting and restart the router....do reply back if it works
Nov 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My wireless adapter keeps disconnecting me from the internet, and I can't figure out how to fix it. I have to restart the computer everytime. I also can't pick up my laptop or it freezes. I have a toshiba.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this. and your laptop is freezing because you might not have got it serviced from a very long time.
Jul 14, 2009 | Toshiba (PA3212U) Wireless Adapter
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Laptop ip stuck on same nr
You can release and renew the IP.
Go to command prompt and enter ipconfig /release, press enter
and then type ipconfig /renew, press enter
see if it works.
(note:there is a space between ipconfig and the /)
Jan 27, 2009 | Sun 501-4366 X1034A PCI Quad FastEthernet...
Wireless router
I have a friend that works at 2 wire. I've bought a couple of their products. And I'm a computer geek. Unless I miss my guess it shouldn't matter what is plugged into it, be it laptop or desktop. It may be locked down to the MAC address on the NIC, but I doubt it. Anyway you'd just browse to it's embedded webpage and change the setting. The IP address is the same as the gateway address on the laptop plugged into it.
I think I bought that model for my dad but I can't remember the exact model number on it. Anyway the one I bought, and set up for my Dad, I had several different computers hooked up to it and never had a problem.
Nov 08, 2007 | 2wire (1000-400108-001) Router
2wire (1000-400108-001) Router Logo
129 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
