Question about Dell Latitude D600 Notebook
Replace broken usb port on dell latitude laptop
Instructions how to fix or replace usb port o my dell latitude laptop. its the only usb port
  • 3 more comments
  • d_cihak Mar 08, 2009
    i have 2 USB ports and they are broken. when i plug in a usb mouse it won't say that anything has been plugged in
  • hkijombo Mar 13, 2009
    usb port is work properl
  • Anonymous Apr 04, 2009
    i hav the same issue.
  • Anonymous May 21, 2009
    I need to know how to fix the only usb port on my laptop. The teeth are completely broken out of it. Nothing will stay in and I can't get on the internet now.
  • Anonymous Mar 13, 2014
    Usb ports not working properly
    Genius:
  • 2,028 Answers
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Posted on Jul 27, 2008
  • ADT2100 Feb 18, 2011
    one of my usb port is not working. It has loose connection I think. When I press pen drive/ usb device down it shows connection then again stops working? How to fix/ replace it
When i use usb port ether for flash or for mouse the laptop stark
Posted on Jan 01, 2012
My Dell Latitude XP laptop got knocked to the floor. It fell on the side where usb port was connected to printer. Usb port pins are now bent and port is unusable. Dell said I have to replace...
No, it's not the only way, if you have an unused PCMCIA port in your notebook. The width of the PCMCIA port is about the height of a credit-card, and the height of that port is about the thickness of a few credit-cards.
Purchase a PCMCIA adapter that has two or three USB ports.
Insert the PCMCIA adapter into the slot,
and connect your USB device to one of the USB ports.
Oct 10, 2010 | Dell Latitude D610 Notebook PC
Charging problem
Charging port needs re-soldering.
Jul 30, 2010 | Dell Latitude D600 Notebook
DELL LATITUDE D600 USB PORT NOT WORKING
You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
.DELL LATITUDE D600 Drivers Download Link
Feb 05, 2010 | Dell Latitude D600 Notebook
USB PORT NOT WORKING.
Both USB ports use the same driver, so if one works and one doesn't, you have a mechanically bad port. You'll need to replace the hardware to solve the problem. There are usually a lot of bad D600 motherboards on Ebay. Or try to find just the USB port you need. Fairly simple replacement task, but laptop dis-assembly will be required to reach the part.
Nov 12, 2009 | Dell Latitude D600 Notebook
ONE OF MY 2 USB PORTS DOES NOT WORK ON MY DELL LATITUDE D600. I TRIED THE FOLLOWING FIX, >START>RUN> DEVMGMT.MSC AND UNINSTALLED ALL USB CONTROLLERS, RESTARTED MY LAPTOP (WITH WIN XP PRO) WHICH...
Hi Roger,
The Windows command you used to uninstall the USB port is correct. If they all work bar one, then i think its safe to say it's possibly a hardware issue.
The only other fix i can think of is to update the BIOS with the latest version from the Dell support website.
Good luck.
My broken usb socket
Purchase a PCMCIA USB Adapter. Will fit in the little card slot and add 2 or 4 more USB Ports.
Oct 20, 2009 | Dell Latitude D600 Notebook
I need to replace a usb port. I have bought a new usb board, but want an idea how to go about replacing the old board before leaping in cold.
If you are refering to the Dell latitude D600 laptop . This system doesnot have a daughter USB board. The USB ports are on the motherboard itself. Refer the service manual below
http://support.dell.com/support/edocs/systems/latd600/sm/index.htm
If you are seeking help for a desktop, You need to open the cover from the tower. And connect the USB card on the white long PCI slots on the motherboard.
Thanks for using fixya
proton
Aug 15, 2009 | Dell Latitude D600 Notebook
The usb of my dell latitude c400 notebook is malfunctioning
Unfortunately, I have seen this many times. One of the major problems with the C400 model was the USB port failing. I have had many of them replaced under warranty, and I have repaired some. The USB port breaks loose from the mother board and stops working. It is possible to SOMETIMES disassemble the laptop enough to get to the port and re-solder the USB port connections. But is is a slow process for experienced people. And it does not work all of the time. i know that this is not the answer that you wanted.
Good luck with it.
~ Spoem
Mar 18, 2009 | Dell Latitude C400 Notebook
MotherBoard gone wild
You can replace it. But how good are you with Soldering?
The easiest (and least challenging fix) is to buy a PCMCIA USB 2.0 card. It'll fit right in your PCMCIA Slot and give you full USB 2.0 (I think your model is only 1.1 if I'm not mistaken)
They run about $20-$30 max for one of them. Just do an eBay search. They can also be ordered in at most computer and specialty laptop stores.
Oct 24, 2008 | Dell Latitude C640 Notebook
Dell latitude c610
sounds like a mother board replacement,if theres a repair shop in your place,you can ask them if they can replace your DC jack..its hard to replace it since its soldered onto the board..mobo replacement is the fastest way..
Oct 20, 2008 | Dell Latitude C610 Notebook
Dell Latitude D600 Notebook Logo
6,913 people viewed this question
Alun Cox
