Question about Saeco Vienna De Luxe Espresso Machine
Boiler with a true saeco vieena de luxe
Hello in the coffee machine there is a true a round true in the boiler and leaks water, can I solde it, if are of aluminium the boiler walls what can i do to repaire it.
yours.
  • 1 more comment
  • mandelgado Jul 27, 2008
    hello mirran but there is a true in the boiling metal wall in the front ...is it possible to welt it o do something a thread and put a screw.
    thankyou
  • mandelgado Jul 28, 2008
    is there a possibility to add a picture to see the true.
    this is the hole it look as man made, or is anything missing in it
    thanks for your help
  • 515 Answers
There are two things you can do.
  1. Get a gasket with spare part number 9011.129
  2. Get a new boiler spare part number 286473055 (120V), 286472858 (230V)
Posted on Jul 27, 2008
  • 1 more comment
  • Mirko Blas
    Mirko Blas Jul 27, 2008
    Can you take a picture of it and put it in here so i can see how it looks, there are two types of boiler to vienna. I´m not sure what you mean and if i can get a picture then i can help you better.
    /Mirran
  • Mirko Blas
    Mirko Blas Jul 28, 2008
    Is your boiler round?
  • Mirko Blas
    Wow, that hole should not be there:-(
    You have to replace your boiler.
There's is water leaking inside my Saeco Magic Deluxe superautomatic espresso machine. Is it a bad boiler?
i had a similar problem and found it was just a gasket on the boiler that wasnt sealing properly.i used JB WELD to repair mine.check all connections and/or gaskets for signs of leaks or possibly a broken gasket mating surface.
Dec 30, 2011 | Saeco Magic De Luxe Espresso Machine
Saeco vienna leaks coffe from under the machine.
1-Try changing the seal of the water inlet under the tank (part# NM05.006)
2- Check the o-rings from the water tubes coming in and out of the boiler.
Oct 19, 2010 | Saeco Vienna De Luxe Espresso Machine
Coffee doesnt flow but water gathers in the drip pan instead.
Hi Your problem is probably the boiler leaking. Its located just above the drip tray in the center of the machine. When it starts leaking it goes into the drip tray or on the counter top. If you can remove the top, you can see if the boiler is leaking. There will be a white line between the 2 halves of the boiler.
Feb 09, 2010 | Saeco Magic De Luxe Espresso Machine
Machine will not steam
It sounds like the booster boiler is not functioning properly, either the thermostat tripped or the element is damaged.
Feb 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Vienna de luxe saeco
I look at the picture and the hole should not be there. You have to replace the boiler:-(
Jul 28, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic de luxe SUP 012
open the machine up and follow the line from the spout (which should give the coffee) till the boiler. The spout most likely is clogged.
Follow THIS LINK for parts etc,
Jun 01, 2008 | Saeco Magic De Luxe Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
206 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
