Question about Apex Digital AT2702 27" TV
Tv with built-in dvd player. When a disk is inserted, sometimes it will play, at other times, the prompter will say disk loading and then in a few seconds it will say "no disk" I've tried a Memorex dvd cleaner but it get the no disk prompt.
    Scholar:
    New Friend:
  • 135 Answers
Hi carlos,
Im assuming the disc youve been trying to use is new. Most people who have that kind of problem may find that the lens need special cleaning by a trained technician who may have to open up the set. For another quick fix, try another dvd cleaner (trust me, the expensive ones are usually better), and also wipe the dvd from the interior to the exterior!
Hope this helps,
kc
Posted on Feb 21, 2011
SOURCE:
The go video DV2130 will not read a dvd. It loads, but will not play. Can this be fixed? No longer under warranty
  1. Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  2. If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  3. The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | GoVideo DV2130 DVD Player/VCR
Screen says loading.Then says (no disc)
There are a lot of reasons why that could happen. Sometimes when a DVD player needs to be cleaned it won't read a disk.Sometimes when you try to play a NTSC disk on a PAL DVD player or visa versa it won't play. Region coding could be another issue. And sometime home burned DVDs won't play in certain players.
Mar 03, 2010 | TruTech DV288B3 DVD Player
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 02, 2009 | Coby DVD-209
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
Dec 03, 2007 | Insignia LCDTV26 26 in. Television
Cd's are ok but no dvd's...
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Apr 09, 2007 | Toshiba SD-2800 DVD Player
Apex Digital AT2702 27" TV Logo
62 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
